 Post subject: Clicking Seagate Baracuda 7200.9 Firmware 3.AAJ
PostPosted: March 11th, 2009, 17:47
I am in need of a PCB for seagate barracuda 7200.9 500GB firmware 3.AAJ. Any help? Thank you.
Data on HD
s/n 3PM0KHWC
ST3500641as
p/n PBD148-304
Firmware 3.AAJ
Date Code: 06481
 Post subject: Re: Clicking Seagate Baracuda 7200.9 Firmware 3.AAJ
PostPosted: March 11th, 2009, 18:12
Data on HD
s/n 3PM0KHWC
ST3500641as
p/n PBD148-304
Firmware 3.AAJ
Date Code: 06481
I think, You not need the pcb, you need professional help to solve the platter/head problem instead!
Regads,
Janos
PostPosted: March 11th, 2009, 19:12
I want to try to swap the PCB board, as it has worked for me in the past.
Thanks for your comment.
Anyone have this hard drive? Thanks!
PostPosted: March 11th, 2009, 19:57
In this model a simple pcb swap is useless.
The pcb have some unique data, and you need to transfert this to the other.
Unless you have made another artifical problem(s).
Additionally, i am sure, your drive have head and/or surface problems....
(if you try your good pcb on another working simiar drive, that can be clicking again, because you have not match the unique data.)
Janos
PostPosted: March 11th, 2009, 21:28
Have you done any PCB Swapping before? I have two times, and it worked both times. Thanks! Please pardon my ignorance. Is Seagate different from Maxtor PCB swapping?
I have read that clicking can sometimes be caused by a PCB problem. I may have touched the PCB to something, as the hard drive was in an open enclosure outside of the PC. Thanks!
PostPosted: March 12th, 2009, 4:33
1st q: Yes, about some hundred times. :)
2nd q: yes, it is differs. Maxtor have only some boot code in the pcb, and almost the entire is replaced from the SA, not like seagate.
Janos
Users browsing this forum: Google [Bot] and 103 guests
