 Post subject: AIX recovery software ?
PostPosted: March 10th, 2009, 17:10
I have a hard drive with JFS from an AIX Server.
Has someone any idea how to extract the data ? (BTW: I do not have an AIX Server)
Linux can read JFS, but is a different type of filesystem, indeed it is called JFS2.
This guys have a software for AIX, but I have`t get any answer from them:
http://www.finaldata.com/Products/?s=PRD&c=8
Do you know if it works ?
Any solution around this?
 Post subject: Re: AIX recovery software ?
PostPosted: March 10th, 2009, 17:31
AIX is an HP version of UNIX ..
Try the demo of this; http://www.stellarinfo.com/hp-unix-data-recovery.htm
It may work, it may not
I dont need a gun, I've got a Donk
http://www.youtube.com/watch?v=CwpZFsVyues
PostPosted: March 10th, 2009, 19:36
AIX is OS developed and used by IBM on their RISC6000 series. HP has nothing to do with it.
To add more problems they also use LVM.
I don't know any utility to work with it - you need IBM AIX station.
I'd suggest to send it to somebody big - Ontrack or Seagate.
PostPosted: March 11th, 2009, 14:25
Ufs explorer Pro work with JFS file system!
Angel Data Recovery
PostPosted: March 11th, 2009, 15:55
The best software is R-Studio. Other: Nucleus Kernel for JFS
PostPosted: March 12th, 2009, 9:17
It is not JFS, JFS recovery tools will not work
PostPosted: March 12th, 2009, 12:27
1. R-Studio has no support for JFS. ccamargol - where did you find it?
2. JFS supported by UFSExplorer and Nucleus is the same as the one supported by Linux. It's different from JFS used by IBM AIX.
3. As I've already told, IBM AIX uses LVM, and allocation blocks, most likely, will be messed up.
I still suggest to send it to somebody who has IBM AIX and an experience. PM me if you need more info.
PostPosted: March 12th, 2009, 15:07
Hi All,
Pupok is right , stellers JFS is only for Linux JFS & R-studio does not have JFS support.
I tried both softwares no luck .....
I recently had a HDD with AIX JFS 2 formatted and with lvm ... none of the tools were able to recognise the filesystem.
