 Post subject: WD PCBs without rom chip .... what is the solution???
PostPosted: March 13th, 2009, 12:02
Hello all ,
We all know that the recent models of WD Hdds come without Rom Chip on the PCB so when you replace the damaged PCB with a new one it makes the spindle motor run but when you connect the drive to the Computer it will not detected.
i hear that they merge the rom chip with the microcontroller .... is it right ?
how can i solve this problem???
Best Regards
Ahmed Samy
Ahmed Samy
Al-Ahram for computer services
http://www.alahram-group.com
 Post subject: Re: WD PCBs without rom chip .... what is the solution???
PostPosted: March 13th, 2009, 12:11
Your clue is: Headmap
Best regards,
PostPosted: March 13th, 2009, 12:17
thanks for reply ... but if you please could you provide me with more details?
Ahmed Samy
You have to know how to read and write Microcode.
www.datarecoveryne.com
PostPosted: March 13th, 2009, 12:31
More than headmap is involved. Masked ROM in MCU contains adaptive data as well. This must be transferred to new PCB. Specialized equipment is required. Professional help needed if data is critical.
PostPosted: March 13th, 2009, 15:44
Or you can change the whole MCU to the new pcb .
PostPosted: March 13th, 2009, 16:10
... assuming the MCU is not fried.
To do the job are required :
BGA REWORK STATION (Infrared)
Flux (gel, liquid)
Reballing kit (stencil, flux, balls) to be used with IR rework station
As option : SMD solder cream.
IR means INFRARED.
Ah yes, of course... required to know how to do it.
P.S. before someone says something.. er.. uh... silly : this is the safest equipment to be used for such work. If you have seen youtube videos where hairdryer, oven, frying pans and eventually napalm are used for removing and resoldering a BGA chip, ASK the author of the video to help you. If you can.
PostPosted: March 14th, 2009, 11:15
thank you all for your positive cooperation ... if anybody discover anything concerns this topic .. it will be a pleasure to share us with his knowledge.
Best Regards
Ahmed Samy
Ahmed Samy
PostPosted: March 15th, 2009, 6:25
Or you can rewrite the new pcb with pc3k UDMA . UDMA supports operations of rom with these drive these drives also have backup of rom on platters .
PostPosted: March 16th, 2009, 8:39
SD's HDD Dcotor for Western Digital has ability to rebuild rom using non native pcb. Havent tested it yet though.
PostPosted: March 16th, 2009, 16:10
The problem at present, without combo tools like SD / ACE is not read the rom... is write the rom (I mean the Marvell MCU...) :D
PostPosted: March 17th, 2009, 4:28
It does work, I tried it on a 1Tb ROYL drive. Needs to be same family drive, then it works a treat!
PostPosted: March 17th, 2009, 4:36
PC-3000 UDMA has a perfect function for ROYL's (Marvel without ext.rom) - ROM Recovery. You should find compatible PCB and just write inside it ROM from SA on the platters.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
Users browsing this forum: Google [Bot] and 249 guests
