 Post subject: Problem with maxtor 6y160p0
PostPosted: March 15th, 2009, 0:09
suddenly my maxtor just locked by it self.
well
is there a way to fix it?
i have tryed some applications like victoria and mhdd32 etc etc..
found FW in the filearchive, but what now? i certanly cant find a update tool that looks like it can do the job...
Code: yar41bw0(o?)
Sn y46qg4pe
6y160p0042811
ide interface
Diamondmax plus 9 160gb ata/133hdd
if i just had the unlock code or a fw to flash or something it would work.
any ideas?
 Post subject: Re: Problem with maxtor 6y160p0
PostPosted: March 15th, 2009, 4:33
What were you doing immediately before the security mode change happened?
Were you just using your computer or were you using a disk related utility?
PostPosted: March 15th, 2009, 14:47
i think it was the fault of an ide-sata converter i tryed
PostPosted: March 15th, 2009, 14:50
MHDD, Victoria, and another programs are only soft wich send "ATA commands" and get " ATA register´s anwer´s control, status, etc, u should be on first read T13.org to understand some about how hdd "communicates with the HOST, the way of how the hdd works :D , after that u could understand what did u get with that soft and u evaluate the problem and get the solution,
PostPosted: March 16th, 2009, 8:18
problem is known, just need unlock code
Users browsing this forum: Google [Bot] and 159 guests
