 Post subject: PCB change for WD disks
PostPosted: March 13th, 2009, 12:16
Hello there
I have a WD1600AAJS, its PCB 's roasted. I want to change it but I do not want to solder the ROM chip etc, I just want to know which numbers should match, in order for the new pcb to be fully compatible with the disk.
Anyone can please give me this info?
Also, there are two numbers on the PCB, one printed on the circuit and one on a sticker. Which is the most important?
The disk is WD1600AAJS-00PSA0
THANKS!!!
 Post subject: Re: PCB change for WD disks
PostPosted: March 13th, 2009, 12:21
northwind wrote:
Hello there
THANKS!!!
There is no other way around soldering a ROM chip, it is of course, if your drive has one.
Actually, if you take it to a pro, you won't have to worry about anything.
www.datarecoveryne.com
PostPosted: March 15th, 2009, 5:22
Hi
The doner hdd pcb must have :
1-Model number must match.
2-DCM codes for the 5th and 6th number must
match
Good luck.
PostPosted: March 15th, 2009, 11:49
Thanks for the replies i appreciate it.
PostPosted: March 15th, 2009, 13:06
It's like saying that you want to do a valve job on your car, without removing the valve cover . . .
You might get lucky. Then again, you might not . . .
http://www.datasaversllc.com
Users browsing this forum: Google [Bot] and 57 guests
