 Post subject: PCB Exchange problem Hitachi Plat 80 GB
PostPosted: March 16th, 2009, 10:22
Hi
I have a Hitachi Plat of 80 GB with the damaged PCB.
I got another PCB and I replaced it to the hard disk, rewrite the NV-RAM.
Now the hard disk recognizes it totally (Model, firmware, modules, etc)
I made an SA Checking Test and everything was perfect.
When I try to extract the data or when I make a recalibration, the disk presents
the following sound: tac, tac, tac, tac.... and power off
Because this happens?
Carlos.
 Post subject: Re: PCB Exchange problem Hitachi Plat 80 GB
PostPosted: March 16th, 2009, 15:27
What shows express utility?
Maybe you could clone the data without recalibration? :D
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: March 17th, 2009, 9:32
It didn't work cloning the hard disk.
Some other idea?
PostPosted: March 17th, 2009, 9:58
Did u tried to read a surface scan? maybe there are bad surface or a bad head
PostPosted: March 17th, 2009, 10:33
Some other idea?
Try to run express test from universal utility. Do you know how to do it?
Or use magic key....Alt+V
PostPosted: March 17th, 2009, 21:33
very bad in express test...
please help me!!!
imagen.doc [119.5 KiB]
Downloaded 683 times
PostPosted: March 17th, 2009, 23:00
Try the end , middle. See if you have same results.
www.datarecoveryne.com
PostPosted: March 17th, 2009, 23:43
Could be a bad head zone, tried to build a head map, and check, that
PostPosted: March 24th, 2009, 18:38
It didn't work head map the hard disk.
Some other idea?
PostPosted: March 24th, 2009, 19:46
Some other idea?
Another option is to send it for a professional recovery.
Users browsing this forum: Google [Bot] and 6 guests
