 Post subject: ST380011A
PostPosted: March 18th, 2009, 14:39
Hi to all!
Look
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz - Head Mask 0000 - Switch to full int.
Spin Ready
3.54 06-11-03 16:59
(P)PATA Reset
T>/1
1>N 5
Attributes
0000: 0a 00 01 0f 00 3d 39 00 66 3a 01 00 00 00 03 03
0010: 00 60 60 00 00 00 00 00 00 00 04 32 00 63 63 79
0020: 05 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00
0030: 00 00 07 0f 00 54 3c 4b 99 11 12 00 00 00 09 32
0040: 00 5f 5f e5 12 00 00 00 00 00 0a 13 00 64 64 00
0050: 00 00 00 00 00 00 0c 32 00 63 63 2b 07 00 00 00
0060: 00 00 c2 22 00 25 34 25 00 00 00 00 00 00 c3 1a
0070: 00 3c 38 00 66 3a 01 00 00 00 c5 12 00 64 64 00
0080: 00 00 00 00 00 00 c6 10 00 64 64 00 00 00 00 00
0090: 00 00 c7 3e 00 c8 c8 00 00 00 00 00 00 00 c8 00
00a0: 00 64 fd 00 00 00 00 00 00 00 ca 32 00 62 fb 02
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 13
0170: 03 00 01 00 01 3a 00 00 00 00 00 00 00 00 00 00
0180: 00 00 4c e3 00 00 06 04 04 04 04 04 04 04 04 00
0190: 00 00 00 00 00 00 00 01 12 fc f6 01 00 00 00 00
01a0: 00 00 51 9e e1 88 c9 00 00 00 00 00 00 00 00 00
01b0: 00 00 00 00 12 fc f6 01 00 00 ff ff 00 00 00 00
01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1>N 6
Thresholds
0000: 0a 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00
0010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00
0020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00
0030: 00 00 07 1e 00 00 00 00 00 00 00 00 00 00 09 00
0040: 00 00 00 00 00 00 00 00 00 00 0a 61 00 00 00 00
0050: 00 00 00 00 00 00 0c 14 00 00 00 00 00 00 00 00
0060: 00 00 c2 00 00 00 00 00 00 00 00 00 00 00 c3 00
0070: 00 00 00 00 00 00 00 00 00 00 c5 00 00 00 00 00
0080: 00 00 00 00 00 00 c6 00 00 00 00 00 00 00 00 00
0090: 00 00 c7 00 00 00 00 00 00 00 00 00 00 00 c8 00
00a0: 00 00 00 00 00 00 00 00 00 00 ca 00 00 00 00 00
0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1>N 7
Hours LBA R-Theta-Z
AutoRd Err 47 at 00f6ba.00.0104
Spin Ready
3.54 06-11-03 16:59
(P)PATA Reset
CE Log EC=0 Rtype=36 OV=0 STStatus0
AutoRd Err 47 at 00f6ba.00.008b
bad Glist? our head bad? :?
Нет ничего невозможного
 Post subject: Re: ST380011A
PostPosted: March 19th, 2009, 2:57
Just try an 1>N1 and see what happend....
www.datasave.ro
PostPosted: March 19th, 2009, 3:41
/T
V4 - G-list
Possibly, many pending.
PostPosted: March 19th, 2009, 8:33
Hi ccc! :mrgreen:
First
Spin Ready
3.54 06-11-03 16:59
(P)PATA Reset
T>/1
1>N 1
Initializing SMART Sectors
clicking and stop!
second
nterface task reset
Spin Ready
3.54 06-11-03 16:59
T>/1
1>N 1
$Switch to full int.
AM Reacquired
AM Reacquired
AutoRd Err 43 at 00e330.00.0000
AM Reacquired
AM Reacquired
AutoRd Err 43 at 00e330.00.0140
smartres.c - ovl L1 failed
Clincking and off!
PostPosted: March 19th, 2009, 8:54
Possible scratch in SA or bad/weak head 0.....From your first post I see the disk starts correctly...What's happend if you try to read sectors in LBA?....
Rgds
www.datasave.ro
PostPosted: March 19th, 2009, 10:08
Rgds
Not read lba
Clicking and off.
Thanks all replys! :!:
PostPosted: March 19th, 2009, 11:16
Hi to all :D
OPENing HDD I found two platters and three heads, I believe that only platter0 and heads0,1, was used… certain? :?:
:idea:
PostPosted: March 19th, 2009, 11:23
ST380011A should be 1 platter and 2 heads....
PostPosted: March 19th, 2009, 11:31
:mrgreen:
PostPosted: March 20th, 2009, 2:37
3.54 06-11-03 16:59
Its kill-head firmware.
Now, you have weak/dirty head 0 too.
PostPosted: March 23rd, 2009, 10:06
Hi to all!
after cleanness of heads, changed the error… :mrgreen:
Error Reading Reserve Track Defect List
F>
PostPosted: March 23rd, 2009, 10:46
your going backwards rather than forwards ;o) :mrgreen:
PostPosted: March 23rd, 2009, 17:15
sempre wrote:
Hi to all!
F>
I suggest to try again, the cleaning, if not helps, try to replace the MHA and try with this one....
Janos
PostPosted: March 24th, 2009, 14:50
Try changing heads .
PostPosted: March 24th, 2009, 15:43
Yes, not work... :shock:
PostPosted: March 24th, 2009, 15:50
Heads, preamp match, are You sure?
The heads died in this hdd, or still works in the donor drive?
PostPosted: March 24th, 2009, 15:54
Yes Works in donor...
:roll:
PostPosted: March 24th, 2009, 15:58
:roll:
What was the issue with this heads in the patient drive?
(terminal?)
PostPosted: March 24th, 2009, 16:12
:roll:
(terminal?)
3.54 06-11-03 16:59
(P)PATA Reset
$Head Mask 0000 - Switch to full int.
Spin Ready
AM Reacquired
$Head Mask 0000 - Head Mask 0000 -
T>Head Mask 0000 - fHead Mask 0000 -
T>Head Mask 0000 -
T>
T>
T>
T>Head Mask 0000 -
T>Head Mask 0000 - Head Mask 0000 -
T>fHead Mask 0000 - f
T>Head Mask 0000 - rHead Mask 0000 -
T>
PostPosted: March 24th, 2009, 16:17
sempre wrote:
:roll:
(terminal?)
3.54 06-11-03 16:59
(P)PATA Reset
Spin Ready
AM Reacquired
T>Head Mask 0000 -
T>
T>
T>
T>Head Mask 0000 -
T>
I think wrong adaptives for this head or not matching heads for this hdd.
The head was clean after you used it in this hdd?
If yes, you shold try another one...
Users browsing this forum: Google [Bot] and 58 guests
