 Post subject: WD Caviar: Thailand vs Malaysia for head swap
PostPosted: March 22nd, 2009, 7:57
Hi all,
has anyone experiences with WD head stack swaps from a Thailand drive to a Malaysian one?
The drives are both WD800BB-**JKC0 (**=55 for the donor, 00 for the target) and from 11/05.
Yes, I've been told about the head alignment problems those drives give, but as it is a single-platter drive, I would like to practice on it.
 Post subject: Re: WD Caviar: Thailand vs Malaysia for head swap
PostPosted: March 23rd, 2009, 5:19
shaun wrote:
Hi all,
It is no matter which drives country.
There are some other trouble aligment.
Angel Data Recovery
PostPosted: March 23rd, 2009, 6:28
Banned User
practice on it and describe clicking noise after that swap in here. :lol:
PostPosted: March 23rd, 2009, 6:57
Thanks for encouraging ;)
I'll describe it, sure. But first e-waste-bay must deliver.
PostPosted: March 23rd, 2009, 11:53
Be prepared to have to image it in the clean room, while you hold the alignment. Although you may be ok becaue it is single platter.
PostPosted: March 23rd, 2009, 12:33
I'm prepared to almost anything ;)
I was just talking to my mech if he sees a chance to make an alignment stand of some kind.
What kind of alignment is it exactly - I think it must be the angle which needs to be aligned, so that the heads are not shifted against each other and "see" the same sector at the same time and not vertical alignment. Right...?
PostPosted: March 23rd, 2009, 12:41
I believe your assumption is correct.
Users browsing this forum: Google [Bot] and 53 guests
