 Post subject: HDD G-LIST - how to reset/fix/purge/edit
PostPosted: February 11th, 2009, 9:33
hi,
after a psu power failure my hd reports SMART attribute -> "Reallocated Sector Count" -> sky high.
my hd is WD800JB-00FMA0
i searched the forum and the web, red a gazillion pages, tried every software out there ( exept PC3000, HTR )
i tried latest WD DataLifeguard, HDD Regenerator, SalvageDATA Sector Repair, HDD Repairer, THDD, MHDD32, Victoria, Secure Erase, and a few more i found here and there, none can fix this.
what software can access the system area that is on the negative sector of the hd and wipe clean the DAMN GLIST ?
thank you.
 Post subject: Re: HDD G-LIST - how to reset/fix/purge/edit
PostPosted: March 22nd, 2009, 20:22
PC3000 UDMA you need a pro to take care of this for you call one before it is too late and you loose all It is hard to do and if you do not understand you will mess up
Iorana Haraharaini
PostPosted: March 22nd, 2009, 23:07
Unfortunately it is a hw and a sw and it costs... More than 10'000 $.
PostPosted: March 23rd, 2009, 1:01
You didn't mention that you're having problems accessing your data. Other than a potentially corrupted SMART attribute value, what problem are you having with your hard drive?
Users browsing this forum: No registered users and 46 guests
