 Post subject: Terminal connection on non Seagate drives
PostPosted: March 24th, 2009, 11:18
Are there any other manufacturers out there that support a terminal connection on their drives besides Seagate?
 Post subject: Re: Terminal connection on non Seagate drives
PostPosted: March 24th, 2009, 12:14
Yes, there are (or were) :D
My Forum
PostPosted: March 24th, 2009, 12:33
Samsung
http://www.datasaversllc.com
PostPosted: March 24th, 2009, 14:59
In older drives Conner .
PostPosted: March 24th, 2009, 15:24
quantum
PostPosted: March 24th, 2009, 17:38
Fujitsu sure looks like it but I have never been able to get it working.
PostPosted: March 24th, 2009, 21:34
Seagate, Fujitsu, Toshiba, Samsung, Hitachi(native), Maxtor, Quantum, Conner - support ASCII terminal
PostPosted: March 29th, 2009, 6:21
@Doomer ,
Which models in Maxtor ?
PostPosted: March 29th, 2009, 7:51
I've noticed on the new Hitachi drives RX and TX are printed on circuit board, but I'm not sure if they are for terminal access or just where they attach their probes during test/manufacture.
Has anyone done any research on this yet ?
PostPosted: March 29th, 2009, 11:35
rameez wrote:
@Doomer ,
All Poker, Ardent etc.
They usually use terminal as debug info during selfscan
PostPosted: March 31st, 2009, 11:28
Can anyone reveal if the Maxtor Calypso has, and if so where, the terminal connection on the Maxtor Calypso is hiding?
PostPosted: March 31st, 2009, 11:31
Calipso has it
I think it has to be in PC3K manuals
PostPosted: March 31st, 2009, 11:46
I don't have the PC3000 manuals because I don't have a PC3000. Not a real one and not a bootleg (sorry).
(What sort of money do I have to fork out for a PC3000 system by the way?)
PostPosted: March 31st, 2009, 12:13
There are not many pins to try :O)
You cannot do much with Maxtor over Serial port read/write/seek/identify other that that no much :O) Oh and of course watch the selftest
PostPosted: April 3rd, 2009, 20:10
so this is probably a really stupid question, but with the other makes/models that support terminal / serial mode. would the "seagate serial adapter" plans apply to these other makes as long as the pins get moved around accordingly? Or is there a magic other way to get terminal to run against drives (and more specifically quantum drives?)
-Chris
PostPosted: April 3rd, 2009, 20:37
Well, here is an example of an PC3000 adapter for Seagate (I removed the delicate pins and used a small header instead).
As shown it works for Seagate. For Samsung, reverse the red and blue wires.
Jono
PostPosted: April 6th, 2009, 11:56
jono-ats,
That looks surprisingly un-complex compared to the schematics here:
http://hddguru.com/content/en/articles/ ... schematic/
granted you did say it is an adapter from the pc3k kit, should i assume that what you are showing actually connects to something like the link above?
PostPosted: April 6th, 2009, 12:28
The Acelab serial adapter is a simple TTL<>RS232 converter
PostPosted: April 6th, 2009, 12:38
You'll need an RS-232 adapter if you don't have something like the PC3000.
The last poster is exactly right.
PostPosted: April 6th, 2009, 12:46
Hello gurus,
I am interested about this topic too.
I know wich model have serial connection, but don't know exactly information about where and how can i connect the terminal...
I mean i can find the possible pins, but how can i be sure if the terminal is silent by default and have no echo from the input?
This is not too easy and there is too many options, like baud start stop bits, transmit methode and similar settings, direction, voltage level, and so on...
If somebody have some info please send me a PM or answer here... :)
Thanks.
Janos
Users browsing this forum: No registered users and 133 guests
