Forum rules
 Post subject: i\\bad problem need help from professional
PostPosted: March 26th, 2009, 10:37
i need help in recover data from bad wd800bb-00jhco
with bad pcb and i use hot sawap but i fount p list of hdd courpt and all module
 Post subject: Re: i\\bad problem need help from professional
PostPosted: March 26th, 2009, 13:56
what program are you using and what equipment are you using to access the SA to read your P list? Do you have PC3000 or what? Also can you post a copy of what you have here so people can see what you have found out. Might help a little to understand more. Sorry
Iorana Haraharaini
PostPosted: March 26th, 2009, 19:42
Perhaps your hot swap didnt work...
PostPosted: March 28th, 2009, 13:18
i use pc3000
and still give errro
PostPosted: March 28th, 2009, 17:31
maybe wrong procedure ? why hotswap ?
PostPosted: March 29th, 2009, 6:34
You have bad pcb ?
