 Post subject: Western Digital Head Alignment
PostPosted: March 28th, 2009, 5:21
Hello there DR gurus.
I need some advice with the Famous Western Digital Head Alignment problem.
I can get the drive ready after finding the correct angle to apply pressue to, but still have problems getting a file structure or imaging the data out.
Drive is WD2500JB-57GVC0
Any of you gurus have better methods of aligning the head instead of holding it down manually at the correct angle?
 Post subject: Re: Western Digital Head Alignment
PostPosted: March 28th, 2009, 12:10
Yes but the principle is the same, only more refined. Still working on it.
PostPosted: March 28th, 2009, 12:26
Karan wrote:
......better methods of aligning the head instead of holding it down manually at the correct angle?
There are tools specifically designed in-house to handle this problem. But as you know, it's not easy to make a really good one that can handle everything.
My Forum
PostPosted: March 28th, 2009, 23:49
Holding the head alignment and doing a 250gb imaging is a PITA.
just asking if any of the gurus know a better way?
PostPosted: March 29th, 2009, 0:41
Create something nearly similar to "Engine hanger" in automotive equipments, however, you need to modify a lot with high precision needed.
http://ktc.jp/catalog/photos/ae901.jpg
Use your imagination :wink:
You won't be needing the chain in that picture for sure :D, but something else :wink:
hint : adjustable & lockable screw with pressure springs needed to hold the heads
My Forum
PostPosted: March 29th, 2009, 10:46
I can't imagine that someone actually sits there with a screwdriver or whatever and attempts to hold the alignment by hand. I certainly couldn't do it. A millimeter or so of movement and the alignment is lost.
I use a low-tech method that leaves the cover on with low-density WDs (e.g. WD200, 400, etc.). I doubt that method would work with the higher density types.
http://www.datasaversllc.com
PostPosted: March 29th, 2009, 12:15
MY fixture was more hi-tech :)
PostPosted: March 29th, 2009, 12:23
Which effect has the pressure applied onto the top bearing? In a factory-assembled drive the screw would be fixed with a typical torque, wouldn't it? But does it matter when the drive has been disassembled, or is aligmnent only a question of the direction and strength of the applied force?
PostPosted: March 29th, 2009, 15:00
No simply the servo is written AFTER the drive is closed and the adaptives calculated / recalculated in THIS condition.
PostPosted: March 29th, 2009, 15:04
:shock:
:mrgreen:
WOW...............
My Forum
PostPosted: March 29th, 2009, 15:17
@blackst: yes, I know. My question was: from experience, what must be taken into account to re-achieve alignment on a disk that has been opened. Sure, the condition before the lid was removed should be restored. But which parameters are important? I've had luck two of three times finding an alignment precise enough to image the disk, the third time it was a Re-Certified drive with a 4-head stack, but only 3 used surfaces.
I'll do this next week on my new victim, the 800BB with the blown flex print. I've ordered medical grade isoprop, lint-free swabs and some injection-grade water from my favorite brain surgery shop ;)
PostPosted: March 29th, 2009, 17:32
<Deleted maybe doesnt apt for all pubic >
PostPosted: March 29th, 2009, 18:29
Interesting :)
ZeBong
" Россия еще раз"
PostPosted: March 30th, 2009, 4:27
instead of trying to find correct alignment, is it possible to recalculate adaptives?
Users browsing this forum: Google [Bot] and 248 guests
