 Post subject: Samsung HD103UI
PostPosted: March 29th, 2009, 22:56
hi to all
i have the above drive that was mounted in an external casing. Drive will power up and spin but not be detected in bios.
Looking at the external drive casing it came from there appears to be a burn mark right where the 2 protection diodes are on the board. the diodes measure ok and i can see no pysical marking to indicate an burns on pcb.
i want to begin by swapping boards to test and see what happens but am not sure if the rom is built in the main chip or not, there is a small 8 pin ic which i think may be the rom but an not sure.
can anyone please clarify if this is the case
picture included.
thank you
 Post subject: Re: Samsung HD103UI
PostPosted: March 30th, 2009, 0:21
Nope, that looks like a transistor / driver array, definitely NOT EEPROM.
I suspect the ROM info is masked in the CPU.
http://www.datasaversllc.com
PostPosted: March 30th, 2009, 0:27
just swapped boards and the patient board works fine on the donor drive, will look at heads now as there is a clicking sound from drive
thx for reply
PostPosted: March 30th, 2009, 2:30
ROM is inside the Marvell CPU. Look at heads...
PostPosted: April 30th, 2009, 3:59
finally opened the drive to start testnig it, pc3000 i believe does not have this family in it for support.
there appears to be fine dust particles on the top platter, the filter also looks a bit black from the dust but still looks quite clean.
the top platter looks to be fine, but cant say about the others platters.
when the drive is powered up it spins up normally, all sounds good, heads move ot outer end of platterand then start clicking and moving bakc and forth just around the outer edge of the platter.
so i suspect there may be some scratches around this part of the platter.
any ideas with which i can further try and diagnose this drive, i can replace heads but this may just be a waste if there are scratches there.
thank you
PostPosted: April 30th, 2009, 4:17
I am sure I don't need to explain why this does not make any sense.
PostPosted: April 30th, 2009, 8:52
I see your point , I could say it was a test to see if anyone pays attention to posts when they are written so you pass.
I meant it was a bit discoloured but more clean than dirty
PostPosted: April 30th, 2009, 12:12
I skipped this thread...
@crecomp : the ROM is inside the big Marvell BGA chip. If clicking with known good PCB same microcode, 99,999999% you have also head problem / preamp. If recal and spin down, the problem is another.
It is important : you have forever BSY, RDY, nothing at all in MHDD ? AND the terminal log what does it show ?
PostPosted: April 30th, 2009, 12:32
If you can see anything in the filter, the drive is already done.
This case needs special techniques to recover only partially.. :(
At this point a really skilled pro can recover about 90-95%.
But if you play more, the chance falls fast to 0.
Janos
PostPosted: April 30th, 2009, 15:55
no no no no... wait... an "impression" can make things appear worse : do a PRECISE analysis of the surface(s) and of the filter before judging the drive.
PostPosted: April 30th, 2009, 22:07
thank you for the answers
BlackSt
i checked the log and it is posted as below.
as for indicator lights i am only getting BSY
PSL
++ SU
MaxPhyHead = 0006
RPM at Handoff: 01DF
UtSHOS - Released on 2008/06/24 16:21 by hyejin8349.kim
DRAM=32MB SoC=26A3
SHOS-(1AA11q6M.128)
L=00000000,00000000
<SpinOn_2>KeepSpinOn!
RV Circuit Enabled
Temp : 26 degC
SpinOk
mServoStatus 00000003
SK C: 93465 H:0
S_0AP:1 C: 15303-> 4145 H:0->0
SK C: 8503 H:0
AP:2 C: 8503-> 4000 H:0->0
SK C: 7084 H:0
AP:1 C: 7084-> 4000 H:0->0
SK C: 10846 H:0
S_0AP:1 C: 4000-> 4000 H:0->0
SK C: 6832 H:0
AP:2 C: 4000-> 4000 H:0->0
SK C: 10313 H:0
AP:2 C: 10313-> 4000 H:0->0
SK C: 6229 H:0
AP:1 C: 6229-> 4001 H:0->0
SK C: 6456 H:0
AP:2 C: 6456-> 3999 H:0->0
SK C: 9884 H:0
AP:1 C: 9884-> 4000 H:0->0
SK C: 6617 H:0
AP:1 C: 6617-> 4001 H:0->0
SK C: 5818 H:0
S_0AP:1 C: 4001-> 4000 H:0->0
SK C: 8011 H:0
AP:2 C: 8011-> 3999 H:0->0
SK C: 6104 H:0
AP:1 C: 6103-> 3999 H:0->0
SK C: 9019 H:0
AP:1 C: 9018-> 4000 H:0->0
SK C: 14075 H:0
AP:1 C: 14075-> 4000 H:0->0
SK C: 6628 H:0
AP:1 C: 6627-> 4000 H:0->0
SK C: 7729 H:0
AP:2 C: 7729-> 4000 H:0->0
SK C: 6998 H:0
SK C: 6873 H:0
SK C: 7278 H:0
AP:2 C: 7278-> 4000 H:0->0
SK C: 6859 H:0
AP:1 C: 6859-> 4001 H:0->0
SK C: 7053 H:0
AP:2 C: 7053-> 3999 H:0->0
SK C: 7717 H:0
AP:2 C: 7717-> 4000 H:0->0
SK C: 7398 H:0
AP:1 C: 7398-> 4000 H:0->0
SK C: 6990 H:0
AP:2 C: 6990-> 4000 H:0->0
SK C: 9918 H:0
AP:2 C: 9918-> 4000 H:0->0
SK C: 8498 H:0
AP:1 C: 8498-> 4000 H:0->0
SK C: 6713 H:0
AP:1 C: 6713-> 4000 H:0->0
SK C: 6950 H:0
AP:2 C: 6950-> 4000 H:0->0
SK C: 6746 H:0
AP:2 C: 6746-> 4000 H:0->0
SK C: 8994 H:0
AP:2 C: 8994-> 4000 H:0->0
SK C: 5253 H:0
AP:2 C: 5253-> 4000 H:0->0
SK C: 5406 H:0
AP:2 C: 5406-> 4000 H:0->0
SK C: 5696 H:0
SK C: 7433 H:0
AP:2 C: 7433-> 4000 H:0->0
SK C: 9022 H:0
AP:2 C: 9022-> 4000 H:0->0
SK C: 5688 H:0
AP:1 C: 5688-> 4000 H:0->0
SK C: 9842 H:0
AP:2 C: 9842-> 4000 H:0->0
SK C: 5553 H:0
AP:2 C: 5553-> 4000 H:0->0
SK C: 7485 H:0
SK C: 5488 H:0
S_2 00000FFF 00000009 0000000A 00000000AP:1 C: 4000-> 4000 H:0->0
SK C: 10665 H:0
SK C: 9480 H:0
AP:1 C: 9480-> 4000 H:0->0
SK C: 18107 H:1
AP:2 C: 18107-> 4000 H:0->0
UF 6 GrayFailErr
SK C: 39302 H:1
AP:2 C: 39302-> 4000 H:0->0
SK C: 5495 H:0
AP:1 C: 5495-> 4000 H:0->0
SK C: 9083 H:0
AP:1 C: 9082-> 4000 H:0->0
SK C: 16935 H:1
SK C: 10368 H:0
AP:1 C: 10368-> 4000 H:0->0
SK C: 7490 H:0
SK C: 7191 H:0
AP:2 C: 7191-> 4000 H:0->0
SK C: 7708 H:0
AP:2 C: 7708-> 4000 H:0->0
SK C: 5747 H:0
AP:1 C: 5747-> 4000 H:0->0
SK C: 6521 H:0
AP:2 C: 6521-> 4000 H:0->0
SK C: 6617 H:0
AP:2 C: 6616-> 4000 H:0->0
SK C: 5976 H:0
AP:1 C: 5975-> 4000 H:0->0
SK C: 6584 H:0
AP:1 C: 6583-> 4000 H:0->0
SK C: 6668 H:0
AP:1 C: 6667-> 4000 H:0->0
SK C: 9855 H:0
AP:2 C: 9855-> 4000 H:0->0
SK C: 5842 H:0
AP:1 C: 5842-> 4000 H:0->0
SK C: 6924 H:0
AP:2 C: 6925-> 4000 H:0->0
SK C: 6210 H:0
AP:1 C: 6211-> 4000 H:0->0
SK C: 6892 H:0
AP:1 C: 6892-> 4000 H:0->0
SK C: 6688 H:0
SK C: 5501 H:0
SK C: 7374 H:0
AP:2 C: 7374-> 4000 H:0->0
SK C: 7662 H:0
AP:2 C: 7662-> 4000 H:0->0
thank you
PostPosted: May 1st, 2009, 2:40
I'll PM .
PostPosted: May 2nd, 2009, 22:04
hi all
i obtained a donor and tried the head swap, i seem to be getting the same noise and log below,
PSL
++ SU
MaxPhyHead = 0006
RPM at Handoff: 01E2
DRAM=32MB SoC=26A3
SHOS-(1AA11q6M.128)
L=00000000,00000000
RV Circuit Enabled
Temp : 27 degC
SpinOk
SK C: 98544 H:0
S_0AP:2 C: 15937-> 4144 H:0->0
SK C: 12946 H:0
AP:1 C: 12946-> 4000 H:0->0
SK C: 6463 H:0
AP:1 C: 6463-> 4000 H:0->0
SK C: 9514 H:0
SK C: 9517 H:0
AP:2 C: 9517-> 4000 H:0->0
SK C: 4964 H:0
AP:2 C: 4964-> 4000 H:0->0
UF 4 1stVelErr
SK C: 4538 H:1
S_0AP:1 C: 4539-> 4000 H:0->0
SK C: 6403 H:0
AP:1 C: 6403-> 4001 H:0->0
SK C: 6660 H:0
S_0AP:1 C: 3999-> 4000 H:0->0
SK C: 7257 H:0
AP:1 C: 7257-> 4001 H:0->0
SK C: 6618 H:0
AP:2 C: 6619-> 4001 H:0->0
SK C: 7450 H:0
AP:2 C: 7450-> 4000 H:0->0
SK C: 6063 H:0
AP:2 C: 6063-> 3999 H:0->0
SK C: 5883 H:0
AP:2 C: 5882-> 3999 H:0->0
SK C: 7878 H:0
AP:2 C: 7878-> 4000 H:0->0
SK C: 5250 H:0
AP:2 C: 5250-> 4000 H:0->0
SK C: 6593 H:0
AP:2 C: 6593-> 4000 H:0->0
SK C: 13857 H:0
SK C: 12012 H:0
AP:1 C: 12012-> 4000 H:0->0
SK C: 11022 H:0
AP:1 C: 11022-> 4000 H:0->0
SK C: 6597 H:0
is there any one who can point me in the direction of trying to analyse the above logs in order to try and mabye solve the issue,
ths log was taken from the original drive with original bord and donro heads.
thank you
PostPosted: March 18th, 2011, 21:16
When I go to turn the computer on, the mainboard powers it up, it makes a clicking sound, like a relay activating every few seconds, it eventually gives up trying to work, and never shows up on windows as a hard drive. What is happening I have all my important data on this disk?
Users browsing this forum: Google [Bot] and 104 guests
