 Post subject: Is there any software to sort out bad JPG and good JPG?
PostPosted: March 31st, 2009, 23:06
I have 120,000 JPG files recovered from bad sectors/bad media with 30% from 120,000 jpegs are corrupted, normally i select the jpeg manually by looking at the thumbnail, However dealing with 120,000 is driving me crazy and time consuming.
Have you guys come across a software that can separate corrupted JPEG from its header file and automatically sorted good and bad?
Just wondering can winhex handle that?
Thank you.
 Post subject: Re: Is there any software to sort out bad JPG and good JPG?
PostPosted: April 1st, 2009, 4:49
You can use the File Listing and Testing app placed here: http://www.datarecoveryengineer.com/
PostPosted: April 1st, 2009, 7:23
Another simple solution : display in the detailed list CAMERA MODEL, date of shot and ATTRIBUTES. Usually a corrupted JPG won't show camera model and/or attributes.Otherwise there are a lot of programs to do the job. Honestly, I have written a simple tool to do it : read the file, define boundaries, get metadata and extended data and then rebuild a correct JPG. You can do it with common APIs and a little programming. My need was for getting a good JPG file from the 400MB common pictures recovered by RAW recovery.
Users browsing this forum: Google [Bot] and 107 guests
