 Post subject: SEAGATE 7200.10 WITH 3 PLATES
PostPosted: April 3rd, 2009, 10:39
Hi to all,
I have a question that goes to the people of this forum to recover data. I have a Seagate hard drive with 3 plates to be damaged the motor shaft, so I should get a donor and make the change. But this disc has the plates separated by a plastic base, so it could not use the extraction plates. If the plates are removed one by one, lose sync? This drive data could be recovered? or any procedure would not work.
Thanks for your reply...
 Post subject: Re: SEAGATE 7200.10 WITH 3 PLATES
PostPosted: April 3rd, 2009, 10:43
The very fact you do not know enough about alignment suggests you should seek professional assistance
PostPosted: April 3rd, 2009, 10:52
Dont move those platters separately or the drive is lost forever.
All three platters have to be moved at the same time keeping the exact alignment.
Best regards,
dobre
Murphy was an optimist
PostPosted: April 3rd, 2009, 11:05
Don't even think about opening that drive! if you really want to DIY it, spend £5000 on a platter extraction system (i've heard its fantastic! :roll: ) or send it to a pro who could do it for $1000 possibly less.
PostPosted: April 3rd, 2009, 11:09
Thanks for your reply dobrevjetser.
I hope you can help me with my query. when a disk has three platters and this are separated by one base. This base does not allow me to use the HD HPE PRO salvation data. What is the procedure for moving these plates to another motor?
PostPosted: April 3rd, 2009, 11:10
Even if u take off all platters without missalignment, could be another problem after the PE :wink: , by his reason u need to send to a Proof DR Company .
PostPosted: April 3rd, 2009, 11:15
For moving such platters newer tools are neccessary, but beto is right; it could well be there are other problems too. I wont disencourage you to try, but be aware that its on your own risk and that DR companies dont like to work on disks that have been tampered with.
You are the judge of how much you data is worth.
Best regards,
Dobre
PostPosted: April 3rd, 2009, 11:18
HDD Spaz,
Hi, I work for a data recovery company, but we never had a problem with this disc. I just wanted you to help me explain how we overcome this kind of problem.
PostPosted: April 3rd, 2009, 11:34
markcarq wrote:
Hi to all,
I feel sorry for the poor smuck who sent his hard drive in to your company. I think you have no business calling yourself a data recovery company. Maybe a software only computer forensics company but not data recovery.
The secret is moving the platters together as one, without losing alignment. It's that simple.
PostPosted: April 3rd, 2009, 11:40
markcarq wrote:
HDD Spaz,
If you are unable to deal with platter alignment on a 7200.10 then maybe you should reconsider your career. To be a competent DR company dealing with problems such as this should be relatively simple for you.
PostPosted: April 3rd, 2009, 12:23
HDD Spaz,
I thought this forum was to help people who have many years to recover data that only took two or three years. I guess you learned not born and thought I write concern was to receive a positive response from you.
PostPosted: April 3rd, 2009, 18:09
markcarq wrote:
HDD Spaz,
well this is the DR Industry , a lot of people here spend a lot of his life, doing research ,developments and lot of money to get that knowledgment
PostPosted: April 3rd, 2009, 18:15
That's your mistake
This forum is for people who are willing to communicate and help each other
Since you cannot help anyone on this forum (because your knowledge level is poor) - you will no get any help from others (most likely)
If you want to get knowledge you need to analyze "raw data" from this forum (which is free but takes time) or pay somebody for exact solution (which is not free but saves time)
I guess you wouldn't disagree with "time is money"
PostPosted: April 4th, 2009, 1:58
To make things simpler: you get revenue from your job? Invest some money on info (know how).
Users browsing this forum: No registered users and 258 guests
