 Post subject: WD5000AAKS - Head change
PostPosted: March 2nd, 2009, 13:27
Hi to all,
i received this wd disk, and when i open it i notice that is missing 5 Heads, and i dont see the heads in the disk.
So if i dont see the Heads but the heads are somewhere in the disk.
I order a donor, and afther change heads in it try to callibrate 3 times them stop.
The DCM first 3 numbers match, and also motor number match.
Afther this i open the disk and see if the good heads are "missing / damage " but see that the heads are there.
I had one case that the heads are missing but where stuck in the platte and i could see and remove it.
Any comment please ?
Ze
ZeBong
" Россия еще раз"
 Post subject: Re: WD5000AAKS - Head change
PostPosted: March 2nd, 2009, 13:58
Zebong, DCM is not important.
This drives from same family --YG-- and this is one of the conditions.
You should compare head map in both ROM's. It's must be same. This is second codition.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: March 2nd, 2009, 15:19
Hello zebong i would check, for magnetic dust over platters that family has some tendence :(
PostPosted: March 2nd, 2009, 16:12
Just curious : where the heads did end ? In the filter ? :D
PostPosted: March 2nd, 2009, 16:28
Hi.. :mrgreen:
it does not have damages in platters? :?:
:idea:
Нет ничего невозможного
PostPosted: March 2nd, 2009, 16:45
Another curiosity : did you find the heads in these conditions ? For me this drive is a desperate case (user intervention ?!?) :shock:
PostPosted: March 2nd, 2009, 17:20
yes, i found the heads like this...
And dont find yet the missing heads, the filter was clean, very clean.
ZeBong
" Россия еще раз"
PostPosted: March 2nd, 2009, 17:28
I vote for heads being captured by the VCM magnets . Remove top pole and take a look there because the drive is not a bathtub and there's no sink :mrgreen: the heads, unless ground in nanoparticles, should be there.
PostPosted: March 3rd, 2009, 0:46
There is a slim possibility of a heads stuck to a platter, that what probably took new heads (if I undertood correctly)
www.datarecoveryne.com
PostPosted: March 3rd, 2009, 1:21
I think the platters are damaged and contaminated, head exchange will be wasting.
PostPosted: March 5th, 2009, 13:49
The heads are almost 99% sure on the magnet. These magnets are very strong and it is lickely the heads are blown towards the magnet, while the drive was spinning.
I have eaxactly the same drive which needs a head swap (WD5000AAKS-00TMA0). I am curious if you managed to get the alignment OK and if so how you did it. Did you use the ramp for the swap or just a different tool?
PostPosted: March 5th, 2009, 14:26
Hi in this case was not easy change heads , i could do it with a tool that i build and using the ramp.
Abou the aligment .... i am trying :( :( no sucess at the moment
Any info are welcome.
Ze
ZeBong
" Россия еще раз"
PostPosted: March 6th, 2009, 19:44
I have also seen where the heads were ripped off and stuck to the platter.
PostPosted: March 10th, 2009, 18:02
I found many heads stuck on the gasket of the cover.
PostPosted: March 10th, 2009, 18:41
The rest of the heads are on the hands of the end users :D
PostPosted: March 10th, 2009, 18:59
i am just working on the aligment ...... :shock:
ZeBong
" Россия еще раз"
PostPosted: March 11th, 2009, 12:15
Banned User
I DO NOT believe that this drive wasn`t open before and someone remove those heads previously.
so ..... zebong tell us a real story
PostPosted: March 11th, 2009, 12:53
Wait ....
what i said is when i open the disk it was missing the heads but the disk came to me closed with seal, i open it.
What happen to the disk it was dropped by the client so heads jump.
At the begginer dont see any heads, but i could find just two.
The others heads is in the disk inside dont knwo where !!!
ZeBong
" Россия еще раз"
PostPosted: April 13th, 2009, 20:41
Hi Guys,
I have a WF5000aaks-00tma0 RE-CERTIFIED which fails on me some time ago. I have some important photos and document on it. I like to recover at least some part of it.
I found the replacement with the exact model number but different month in the same year produced.
I have briefly opened it up to see inside and hooked up with the PC. Well right after turn on the drive I saw that arms moves onto platters and makes couple of back and fort then stopped spinning.
There is no damage either on platters or arm/head. My aim is to swap the platters if can. I know there should be some sort of balance requirement with this type of hard drive that I do not know.
Has anyone done anything similar what I am trying to do? At this point any help is deeply appreciated.
Thank you
PostPosted: April 13th, 2009, 21:02
Please tell us how you have decided that a platter swap is what's needed for this drive. Is it "accepted folk wisdom"? Did you see it done on an internet video? I am really interested in your decision process, because many people come to this forum thinking that a platter swap is the next step for whatever problem they face.
Unfortunately, you opened the drive, most likely in a contaminated environment. Once you pop the cover on these drives,re-alignment is a very difficult necessity . . . if the drive hasn't already been destroyed by particles.
It may have been that your drive had a PCB problem -- not a mechanical one. It's time to call a pro for sure. There is nothing more you can do except lose your data forever, if you keep working on it.
Sorry, but that's the truth.
http://www.datasaversllc.com
Users browsing this forum: No registered users and 119 guests
