 Post subject: Accidentally killed hard disk
PostPosted: April 13th, 2009, 20:37
Hello guru's,
I accidentally killed my hard drive! It is a 5v notebook drive installed inside an external enclosure. I got into a muddle and accidentally plugged a 12v ac adapter into the enclosure and now a chip on the drive pcb has burnt.
My question really, is, if I was to source an exact same drive model and swap the pcb is it likely to work?
 Post subject: Re: Accidentally killed hard disk
PostPosted: April 13th, 2009, 21:05
No, it won't. There is firmware on the bad logic board that needs to be transplanted, too.
There's also a good chance that the wrong voltages toasted the preamp inside of the sealed enclosure. I'm afraid it's pro time if you need your data.
http://www.datasaversllc.com
PostPosted: April 13th, 2009, 21:21
is the firmware the small 6-pin eprom type device on the top-left of the picture? I could easily remove and swap that. Do you think there's a large chance the pre-amp is also damaged? I do have a backup of the data, but it's from last month.
PostPosted: April 13th, 2009, 21:50
No, the EEPROM on these is a small 8 pin device along the side not shown in your photo.
Sure, the preamp might be damaged. But not 100%. Feeling lucky? One way to find out . . .
PostPosted: April 14th, 2009, 0:54
this ATDA have no NVRAM ,,only ROM... simply find a same DONOR ATDA 20 will help you....
Спасибо
СУТИОНО / АПИНГ
PostPosted: April 14th, 2009, 1:46
Yes. If clicks or don't work need pro service (if data really needed). Worth a try.
PostPosted: April 14th, 2009, 9:18
Oops. The others are right. No ROM on this one. Sorry
PostPosted: April 14th, 2009, 9:30
Just match the 1st two lines of the code on the white sticker on the PCB.
If the only fault IS the pCB then it'll work, if it clicks you have head/preamp problems.
Then it's pro time.
PostPosted: April 14th, 2009, 16:15
Many thanks, but there is no white sticker on the pcb (except made in Czech Republic)?
PostPosted: April 14th, 2009, 17:16
I can see that sticker on your drive.
It starts with 07N7585
www.datarecoveryne.com
PostPosted: April 14th, 2009, 17:21
Yep, that looks like the sticker that should be on the PCB.
PostPosted: April 14th, 2009, 18:08
great. Looks like I'm in luck, there's on on ebay listed with that exact same code.
Will have a go with that. Thanks for all your help
PostPosted: April 14th, 2009, 18:19
I've almost certainly got one too.
Just realised you're in UK.
PM Me
Sean
PostPosted: April 16th, 2009, 9:14
Well, I purchased the pcb from Ebay and the drive is now working. Interestingly, I received a 07N7585/F80183A pcb, the original pcb was a 07N7585/F80183E - this was also the board shown in the ebay auction. Just goes to show you can't trust the pictures on ebay auctions!
Users browsing this forum: No registered users and 204 guests
