Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Maxtor Safe mode jumper
PostPosted: April 12th, 2009, 6:55
No external ROM is not required for switching to ALT-SA .
yes you can .
PostPosted: April 13th, 2009, 15:18
Hi all!
Yes I have backed up all modules.
This hdd is just for training. No important data on it.
Question: What does it mean if after boot from fdd, the hdd led flash 3 times short pause and repeat it ? (Maybe error in (ss) module)?
PostPosted: April 14th, 2009, 16:43
Hi all!
How to repair a corrupt 33h module on N40P? Is it possible?
Maybe someone knows the answers and help
PostPosted: April 14th, 2009, 16:49
Iszerda wrote:
Hi all!
Because you trying to use the hddrepair, wich have shifted module numbers, better to use the HEX UBA number instead of module number....
Janos
PostPosted: April 14th, 2009, 18:15
Thanks Janos for your help.
Is it possible to repair a corrupt HLISTS (33h/34h) module on N40P without PC3000/HRT?
PostPosted: April 14th, 2009, 18:21
This module is not neccessary for drive startup.
But have inside unreproducible data.
Only selfscan can rebuild this module for you.
If you want the data, the way you are is not working. :D
If you want the drive, simply forget this module....
Janos
PostPosted: April 14th, 2009, 18:41
Thanks again Janos!
No I do not need data .
I am thinking about if SS modules are corrupted in SA or SAC.
What will happen if I start SS ?
PostPosted: April 14th, 2009, 18:46
It depends on what do you planning to do.
If you SS from A, the module will be rebuilt again. (or will fail the process, if the ss can't reallocate the defect)
But if you are in C, the SS will fail, and will left the drive for a brick. :D
Janos
PostPosted: April 15th, 2009, 12:32
Hi Spildit!
Which module(s) contains the SelfScan script on N40p?
I assume 0Eh is that. Is it correct?
Can you explain please...
Selfscan can repair a corrupt Hlists(33h) module?
Thanks for replies
PostPosted: April 15th, 2009, 15:31
Thanks a lot Spildit!
I will read all. My search missed this. :oops:
Funny - adviced to clear the defect list - :wink:
PostPosted: April 15th, 2009, 19:14
Online
ss will rebuild defect lists anyway...
PostPosted: April 16th, 2009, 16:31
Thanks pepe!
So SS will repair 33H (HLISTS) module too.
PostPosted: April 16th, 2009, 16:43
Hi all!
What is the size limitation of HD Duplicator Demo (30G) ?
I can clone a N40P (40G) with this tool. Why?
PostPosted: April 16th, 2009, 17:50
SS won't repair 33, will exit instead if corrupted.
PostPosted: April 17th, 2009, 6:46
Not so clear this about 33h mod.
Spildit wrote:
Before you run Self Test from main service area you are adviced to clear the defect list and the PN=33H. That is necessary to enable Self Test routines to hide defects correctly."
OK. Maybe this way : Clear a corrupt 33h and after SS...
How can I clear this module without PC3000/HRT?
Thanks for replies.
PostPosted: April 17th, 2009, 7:38
AFTER SS ? If SS ended OK you don't need to touch it. Before : write a clean 33.
PostPosted: April 17th, 2009, 14:09
Iszerda,
You need to clear this module for be sure the SS will run smoothly. 8)
It will rebuild the contents inside, if the original was a clean and good one.
If not, maybe BlackST have right, the SS can exited abnormally, but it depends on model/script/prog and so on, in this way, who knows before try? :shock:
Anyway, as i sad, it depends generally on what do you want to try?
Wich 33h module is damaged, and you planned to run wich SS?
Janos
PostPosted: April 17th, 2009, 14:41
He has bad Sa and want selfscan to fix it.
PostPosted: April 17th, 2009, 15:16
I know the situation, but as i see, you can't read between the rows. :P
Janos
PostPosted: April 17th, 2009, 17:25
Why not speaking clearly then?
Users browsing this forum: No registered users and 309 guests
cron
