 Post subject: ST380011A Problem
PostPosted: April 21st, 2009, 0:07
ST380011A model is not detecting , 80Gb detected as 128gb , serial no is correct, can read sa surface, but getting error while reading tracks, can you figure out what is the problem ?
Data Recovery in Kerala
 Post subject: Re: ST380011A Problem
PostPosted: April 21st, 2009, 4:05
As you can see, the drive is not detected correctly.
So you have to check why. Maybe even the problem is not on the drive, but on cabling.
PostPosted: April 21st, 2009, 14:50
Thank you dmarques,
I think you were right, i couln't see anything without connecting terminal, but how can i check my ide connection circuit , can you help me please.
PostPosted: April 21st, 2009, 14:58
Seems unusual for model to be wrong, but not garbled, and also serial number and all other parameters are correct.
Have you verified a working drive on the channel? Does HDD still give same ID on alternative station, such as MHDD station?
Do you have legitimate Acelab PC3000?
PostPosted: April 21st, 2009, 15:03
It looks like the drive is ss'ed, or loosed the STUFF.
Janos
PostPosted: April 22nd, 2009, 14:17
Firstly better to show here terminal log.
I could see there reading error (bad heads or corrupted R/W channel on PCB - popular problem on 7200.7)
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: April 22nd, 2009, 14:23
this is my suspicion. Also, in my experience, 7200.7 are prone to surface damage and/or dirty heads. terminal would help.
PostPosted: April 26th, 2009, 5:28
You have stuffed the drive with default values use edit hdd ID to correct the problem.
PostPosted: April 26th, 2009, 6:05
Terminal Log
PostPosted: April 26th, 2009, 11:06
Has any physical work been performed on this disk?
PostPosted: April 26th, 2009, 23:43
no, i was trying to read using DE , whilw these terminal log
PostPosted: April 27th, 2009, 20:08
You could swap PCB and check terminal again, but from some quantity of these cases I had in the past I would bet heads are about to die.
