 Post subject: Anyone have firmware for a Caviar 33100 (WDAC33100-00H)?
PostPosted: April 12th, 2009, 6:07
Anyone have firmware for an old Caviar 33100 (WDAC33100-00H) or know how to regen the translator? Thanks.
WDAC33100-00H
99-004217-000
Email: support@hddpros.com
 Post subject: Re: Anyone have firmware for a Caviar 33100 (WDAC33100-00H)?
PostPosted: April 22nd, 2009, 5:31
PC-3000 ISA doesn't have an option to regen the translator on this unit. Is there a drive that I can use as a temporary host to regen the trans from the p-list? The drives newer than this one have the regen translator option. Am I out of luck? Thanks.
PostPosted: April 22nd, 2009, 5:49
Hi
I have this working drive:
WDAC33100-32H
1 AUG 97
BHAAJMG
I can send you the SA, if this is good enough for you. :)
Janos
PostPosted: April 22nd, 2009, 9:35
These drives use the same commands as AA series (like WD102AA for example)
I don't get it. How firmware from a different drive would help you to regenerate translator? Which modules are bad?
PostPosted: April 22nd, 2009, 11:12
I think not for regen, but repair.
Sometimes a "sample" mod can help a lot. ;)
Additionally, without the original translator, some type of data can be recovered, like pictures, and so on...
Janos
PostPosted: April 22nd, 2009, 15:48
Sorry, we received two of these drives. One had some minor firmware damage. One has a translator issue. We purchased an identical drive a few days ago and recovered the first one. The second one has damaged copies of mod 20 and 25 (crc errors). First 274k is read but produces SSS afterwards.
PostPosted: April 22nd, 2009, 16:24
just recalc translator then
You don't need any firmware
PostPosted: April 22nd, 2009, 16:31
Theres no option to recalc the translator.
PostPosted: April 22nd, 2009, 16:43
There is allready suggested, to try to do like WD102AA drive... :)
PostPosted: April 22nd, 2009, 22:31
You mean you don't have tools to do that.
Why don't you buy the tools
Your problem is not a problem at all
PostPosted: April 22nd, 2009, 22:55
Doomer, I mentioned up above that our pc3k isa doesnt have a translator feature for this drive. Nevermind, I will try something else.
PostPosted: April 23rd, 2009, 0:50
The best solution - Buy PC-3000 UDMA. :D
How do you work on ancient ISA board?
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: April 23rd, 2009, 3:00
As far as i know, the UDMA not supports this old hdd, or does? :shock:
Janos
PostPosted: April 23rd, 2009, 9:06
HRT should have support for old WD drives
PostPosted: April 26th, 2009, 6:06
ISA supports this model which version of the utility are you running ?
Users browsing this forum: No registered users and 166 guests
