 Post subject: HSA swap wd800jd, donor compatability
PostPosted: April 22nd, 2009, 9:59
looks a fine candidate to me but would like your esteemed opinions. thanks.
 Post subject: Re: HSA swap wd800jd, donor compatability
PostPosted: April 22nd, 2009, 10:08
Hy this WD´s are hard to find donnor´s some years ago i got similar case, donnor was same model, at that time, check " 3 letters" DCM now im know´s DCM doesnt matter, and no works foruntely, at that time, the hdd not knocks, and reach´s readiness only the head test show me error at second head, but after work with the patient was possible to get data , because the head swap, not works, endless knocking, i will suggest for this case get a donnor same model but closest date and tried
PostPosted: April 22nd, 2009, 10:16
thanks Beto. You think my match is not close enough?
Yes disk had click of death, client knocked over while running.
Any closer donors out there? :D
PostPosted: April 22nd, 2009, 10:53
I have couple of those.
www.datarecoveryne.com
PostPosted: April 22nd, 2009, 11:12
Absolutely incompatible donor for Head Swap.
You need:
1. wd800jd - xxMSxx same with patient;
2. Same head maps
3. Malaysia.
I would never send my broken HDD to such 'pros'...
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: April 22nd, 2009, 11:47
Match the Dell P/N DC077 for best possible match.
Data Recovery Ireland
PostPosted: April 22nd, 2009, 11:56
At some models of wd´s even no works if u did head swap using fully same model, same head map , same country, and even same DCM , maybe need´s another thing´s :wink:
PostPosted: April 22nd, 2009, 12:00
i have PM'ed you but know what you mean: alignment.
PostPosted: April 22nd, 2009, 12:59
I would use this one for donor
It looks compatible to me
PostPosted: April 22nd, 2009, 22:35
MS Vs LS still the same class.....
give it a test you will know... it is simple.......
Спасибо
СУТИОНО / АПИНГ
PostPosted: April 22nd, 2009, 22:42
I personally would have thought that this is not a good match. But Doomer has me confused. Would you be able to elaborate on this. Why so many different answers??? :roll:
PostPosted: April 23rd, 2009, 9:05
if the head map , position too its the same, maybe doomer could " so tune " the heads to match on this im think that´s what doomer tried to told us :roll:
PostPosted: April 23rd, 2009, 9:14
LSA and MSA are both Unicorns. They use same hardware. Heads map supposed to be the same - 2 heads H0 and H1
You may need some tricks to make the drive work after transplant but this is usual for WDs
PostPosted: April 23rd, 2009, 9:18
Ahhh... :idea: i see, thanks for clarifying this for me.
PostPosted: April 23rd, 2009, 9:22
My magic crystal ball works :lol:
PostPosted: April 23rd, 2009, 9:52
thanks doomer and beto!
PostPosted: April 23rd, 2009, 12:22
These tricks you speak of....Manually jigging head alignment or altering adaptives for head alignment?
Users browsing this forum: No registered users and 104 guests
