 Post subject: Can Seagate SATA PCB be used on PATA Disk
PostPosted: April 27th, 2009, 5:04
Hi Guys, I have a Seagate 7200.10 500 GB.
It has fried pcb and seized motor. I have completed platter swap using same model number (but donor a SATA drive so there is an S on the end of the model number). I was wondering If I can use the SATA pcb on the PATA disk if I swap the rom. It would save me buying another drive.
 Post subject: Re: Can Seagate SATA PCB be used on PATA Disk
PostPosted: April 27th, 2009, 5:07
This will not work. I have done tests on this and my results are that this will not work.
I have tested this on 2 working 2.5" MERC2 drive (ST9..23A(s)), 1 SATA 1 PATA, and even with native ROM on, disk does not work if different interface PCB is attached.
I have not tried with barracuda, but I highly doubt it.
Wil be nice to see your findings if you attempt though.
PostPosted: April 27th, 2009, 5:37
Thanks for the info. I managed to repair native pcb and get all the data. I will conduct a few tests if I get chance later today.
PostPosted: April 27th, 2009, 7:53
Won't work because of different program to handle the different interface(s). Tried on many Barracudas, no joy. Probably you can do something MANUALLY with overlays.... not sure.
PostPosted: April 27th, 2009, 8:03
thanks for the confirmation. I suppose its not really worth invesigating as pcbs are not hard to repair and source.
Users browsing this forum: Google [Bot], ZeldaMaster501 and 207 guests
