 Post subject: What causes?..
PostPosted: April 28th, 2009, 1:13
scratches on the platters. I opened the drive for a second, just enough to see the scratches then closed it down.
It started with a Unmountable_boot_device, so I ran a chkdsk /r... that never completed it would get stuck at 75% first time then 51% second. I ran active boot to superscan the data but that only showed me deleted files not what I had on the hdd before windows crashed. Now I can hear click,click sounds coming from the drive... there was 2 scratches on the platters. So is this over right, no chance of success?
 Post subject: Re: What causes?..
PostPosted: April 28th, 2009, 3:01
This can be a head crash first...
The chance for successfully recovery is low.
Janos
PostPosted: April 28th, 2009, 3:43
When you opened the drive chances of recovery were medium.
After you ran your tests i would say the chances are as good as zero.
Never continue to work on a drive with scratches.
Dobre
Murphy was an optimist
PostPosted: April 28th, 2009, 17:31
Dobre
How can you find out what causes a click/clack noise without opening the hdd? I looked at the PCB board, there was no burns or toasted chips so.... how are you supposed to find out what is wrong without opening the disks?
PostPosted: April 28th, 2009, 18:22
Dobre
The keyword is: measure and precise diagnose. 8)
To avoid this next time:
results-the-yourself-solutions-t11912.html?hilit=results
Janos
