 Post subject: ST31000340AS SD35 PCB needed to recover 800giga of data :(
PostPosted: April 28th, 2009, 10:11
suddenly the hdd failed and everything is lost unless someone helps me...
 Post subject: Re: ST31000340AS SD35 PCB needed to recover 800giga of data :(
PostPosted: April 28th, 2009, 10:49
A simple pcb swap will not solve your problem.
PostPosted: April 28th, 2009, 11:03
even if the fw is the same?
what can solve my problem exept companies that need 500-1000euro to recover the data?
PostPosted: April 28th, 2009, 11:10
The little part of the fw is on the pcb but in your case this part is unique, not exchangeable, the most is on the platter.
The answer is: It depends on the problem.....
If you want to read more about pcb swap:
results-the-yourself-solutions-t11912.html?hilit=results
Regards,
Janos
What is the original problem exactly?
PostPosted: April 28th, 2009, 11:24
my hdd is not openning from the power, i removed the PCB and i have seen that a chipset is burned
PostPosted: April 28th, 2009, 11:37
Then there is 2 option:
1. preamp (chip inside the clean area) burned, the recovery will be expensive
2. The recovery will be cheap if you find the good company for this.... Much less than the price what you have wrote....
Regards,
Janos
Users browsing this forum: No registered users and 60 guests
