 Post subject: 7200.9 st3250824a EC=43 at ffffffff.00.0002
PostPosted: April 27th, 2009, 23:11
Disk was knocked over by client. It is my first time I have really looked at a Seagate terminal, and what I have seen looks to confirm HSA problems. Disk spins up but is unseen in Bios. Makes my Atola Insight crash on powercycle! ICRC and INDF light red. Any tips please ;)
4096k x 16 SDRAM
TONKA15 - 1_Disk S.59 12-09-05 11:07
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
Failed sys sect. write
Read Ver Retrys
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Unable To Load Overlay 01|000A
 Post subject: Re: 7200.9 st3250824a EC=43 at ffffffff.00.0002
PostPosted: April 27th, 2009, 23:35
If problem started when knocked over then I vote for scratch on SA or platter knocked out of alignment. I've seen that error caused by multiple different things though.
PostPosted: April 28th, 2009, 0:48
My vote is bad HSA (heads cannot write). Actually you could try to read data via terminal and active utility, but this is very slow process.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: April 28th, 2009, 10:19
The drive can't read SA.
Either it's bad heads, or scratch in SA. or both. I would Check the platters for any obvious scratches and change the heads.
PostPosted: April 28th, 2009, 10:30
I would tried to did a test head before any attempt
PostPosted: April 28th, 2009, 11:24
Last time when i see this, it was a pretty good scratch in the SA. :(
I suggest to take a look inside, before power on again, preventing the more damages....
If you see in, you can take a look to the heads too. ;)
Janos
PostPosted: April 28th, 2009, 11:58
thanks guys. I'll take a peak inside. It certainly is tough understanding the possibilities of terminal. I am going to take a few other Seagates I have lying around and play. Aside from the "7200.10 and earlier doc" is there any other documentation with specific test sets that I could be pointed to?
regards
simon
PostPosted: April 28th, 2009, 15:09
you can usually find plenty of google hits on the important part of the error message
PostPosted: May 18th, 2009, 21:56
currently looking for donor:
seagate-st3250824a-7200-hsa-needed-t12275.html
please let me know if you have one
thanks
Users browsing this forum: Stritom and 375 guests
