 Post subject: Clicking after PCB swap
PostPosted: May 1st, 2009, 13:09
where to go after PCB swap...!!!
i swapped my PCB on my WD5000KS
WD Caviar SE16
Model : WD5000KS - 00MNB0
Date : 13 MAR 2006
DCM : HBHCAJCH
PCB : 2060-701383-001 REV A
but on the sticker says PCB : 2061-701383-E00 AC
and now the heads turn on when connected to power but clicking is heared and i dont know what to do next ...anyone can help me plz maybe to tell me which ROM to swap on my old PCB or something like it
 Post subject: Re: Clicking after PCB swap
PostPosted: May 1st, 2009, 13:16
The first question is: What was wrong with the drive that made you think a PCB would work? Did you properly diagnose the drive first? Swapping the PCB without knowing the problem is like a doctor giving you theraflu for a fever; it MAY help, but the doctor didnt diagnose you properly, you could have an ear infection or worse.
PostPosted: May 1st, 2009, 13:20
actually my HDD was not getting any power ...i tried to connect it internal and external and either ways didnt start...so i bought the same HDD but with different data numbers on the PCB and when i swapped the PCBs it started but with clicking and not recognized by windows so i think now that the problem is only the FIRMWARE or the U12 chip or something like it but i dont know what is the next step..
thanks advanced
PostPosted: May 1st, 2009, 13:29
thanks advanced
If you can show a good resolution pic from the PCB's component-side, maybe we can help....
Janos
PostPosted: May 1st, 2009, 13:30
pictures-t11433.html
thanks
PostPosted: May 1st, 2009, 13:53
If after u exchange the Serial ROM, into the Donnor PCB the HDD Knocks, then could be the damaged pass into the MHA, inside HDA, that could be diagnostic by a professional, and not DIY Solutions i can suggest u Dobrebjester he is on beligum and could help u
PostPosted: May 1st, 2009, 13:54
no i didnt swap the roms i only did the PCB swap...
how can i contact Dobrebjester???
thanks a lot
PostPosted: May 1st, 2009, 17:26
PCB swap will NOT with this model, also there is NO ROM to swap, it's masked in the MCU I think.
PM marc (dobrevjester) ("v" not "b")
He's a proper DR pro in Belgium.
PostPosted: May 1st, 2009, 22:45
Hy sean this model WD5000KS has external serial ROM , on U 12 MCU 88i6845-TFJ1 the most time´s it ATMEL family :wink:
PostPosted: May 2nd, 2009, 1:26
Yes, U12 is ROM on these but of all the ones I've ever seen that clicked when powered on, precisely ZERO have been PCB failure only.
PostPosted: May 3rd, 2009, 10:19
So it is Alberto, that'll teach me to try and answer questions after two bottles of red! ;-)
But, even if you do swap the ROM it's unlikely to fix the problem like drccsc says, as these series are prone to bad heads/preamp and very very difficult to fix.
Users browsing this forum: Google [Bot] and 70 guests
