 Post subject: Transcend USB flash NAND flash specs
PostPosted: April 30th, 2009, 23:59
Does anyone know the specs for Samsung K9HCG08U1M (4G) like the page size, block size. etc
I tried PC3000 Flash but it detected as wrong memory type.
Original memory is Samsung K9HCG08U1M , detected as K9LBG08U0M
This is of Transcend USB flash drive:
ALCOR Mircro, AU6984 A53-MHL-GR, A9688601F, 0820.
Managed to read the memory but "wrong signature" therefore no data is visible.
Thank you.
 Post subject: Re: Transcend USB flash NAND flash specs
PostPosted: May 1st, 2009, 15:23
I couldn't find a datasheet, but the page size, block size etc. for that chip, are shown on the last line on page 2 of this small PDF:
ftp://ftp.ingenic.cn/6an/Support%20Memory%20Chip_0810.pdf
i.e. block size = 512kB+16kB and page size = 4kB+128 = 4224
Hope that helps... :)
PostPosted: May 1st, 2009, 21:41
Thank's Vulcan
I am trying to add this NAND to PC3000 Flash known memory database to see if it works, but i am a little doubtful whether the lost partition/file structures are caused by "joining error" or it could be wrong identification of the memory.
This K9HCG08U1M is a single chip with 2 layers, 4G each. Total 8G.
Please see the attached pictures.
Picture 1. Patient NAND detected as K9LBG08U0M
Picture 2. After running automatic and manual this is what i got
Picture 3. This is the spec for K9LBG08U0M
PostPosted: May 2nd, 2009, 7:31
When you say "no data is visible" you mean with the stick or with PC3000 ?
The problem can be likely corrupted configuration in the AU controller... either you fix the stick and read the memory with working stick AND correct controller config. OR try to make PC3000 handle your chip...
PostPosted: May 2nd, 2009, 8:24
not visible in pc3000, tried with working stick, no luck.
Patient: ALCOR Mircro, AU6984 A53-MHL-GR, A9688601F, 0820.
Donor: ALCOR Mircro, AU6984 A53-MHL-GR, A9558801F, 0220.
PostPosted: May 2nd, 2009, 9:58
Terranova,
The trouble is not in the chip spec. It was read successfully.
Now you have to find the way how to join dumps correctly and apply AU algorithm in the PC3K Flash. This controller has mix by blocks plus mix between banks.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: May 3rd, 2009, 0:26
Thanks Creator, i am finding the right join dumps, will let you know the results.
PostPosted: May 4th, 2009, 21:53
Thanks Creator Data Recovered 100%, it was the mix NAND with the right joins from dump.
Users browsing this forum: No registered users and 119 guests
