 Post subject: partition lost drive letter!
PostPosted: May 4th, 2009, 4:16
my hdd has 4 partition but now it has show 2 drive on my computer (C:,E:)but D:,F: was lost .i check at Disk Management, it found 4 partition (2 partition no drive letter no detail ) how can i fix this
picture is here
 Post subject: Re: partition lost drive letter!
PostPosted: May 4th, 2009, 6:16
Assuming you don't need data from those partitions, just reformat them.
Zero Alpha: zeroalpha.com.au
PostPosted: May 4th, 2009, 8:16
you can use partition find and mount to mount those lost partitions
good luck
PostPosted: May 5th, 2009, 0:35
DMDE ->www.dmde.ru
PostPosted: May 5th, 2009, 2:17
Check some old posts here and you will find some good information on partition recovery and some different programs to use. Do not use chkdsk if you want you data back.
Good luck
Iorana Haraharaini
Users browsing this forum: Google [Bot] and 63 guests
