Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: HDD repair 2.0 ENG
PostPosted: March 9th, 2007, 9:05
hi to all
can someone tell me if this program is for pata drives only. i heave sata drive that this program doesent reckognise at all. if there is a setting for this program to enable sata drive please share it with me.
 Post subject:
PostPosted: March 10th, 2007, 14:25
Are you running it directly from the SATA port on your mainboard?
If so, I think HDD repair only work off IDE. So you will need to run your SATA drive through a IDE>SATA adaptor.
Sean
 Post subject:
PostPosted: March 11th, 2007, 3:44
but i think sata drives have different firmware structure then that of ide so i think it will not work on sata drives .
 Post subject:
PostPosted: April 27th, 2007, 4:48
i agree with u mr.sean u r right
 Post subject: Re: HDD repair 2.0 ENG
PostPosted: January 1st, 2008, 21:26
can u give me the (hdd repair 2.0 eng) URL please ?
PostPosted: June 23rd, 2008, 16:20
its only for ide not sata
PostPosted: June 24th, 2008, 3:00
Does this programme actually repair anything?
PostPosted: June 24th, 2008, 13:02
yes its a good freeware utility for repairing maxtor and WD firmware .
PostPosted: June 26th, 2008, 1:51
i got this program but not sure where to get the data lead
you connect up to use it
any ideas
cheers
PostPosted: June 29th, 2008, 18:41
Hi, gurus
I have one error-free and data-free donor drive, NAR61HA0, and playing with HDD repair 1.1, i have made this to NAR61HAZ. :mrgreen:
Is there a way, to fix this kind or error with 2.0 version?
The drive has ARDENT cpu, but the hdd repair shows only DSP and POKER.
Can somebody help me a little?
Thanks,
Janos
PostPosted: June 30th, 2008, 9:37
Ardent = poker .
PostPosted: July 11th, 2008, 3:28
so can anyone tell me where to get the data lead that you connect up to the test pins on hard drive :(
PostPosted: July 15th, 2008, 8:49
:vo:
I want to test it!
Нет ничего невозможного
PostPosted: July 26th, 2008, 9:44
Hello
Somebody have a loader for this model?
6E020L0510231, K,G,G,A, B8FEA
I have already tryd all the loader i have including the one 6E020L on the files in forum, but no one works for me. :(
Additionally i forget to build own loader for this drive, and now i can't make it alive again...
Thank you for all who want to help me,
Regards,
Janos
PostPosted: August 26th, 2008, 19:11
Hi, Someone has a loader, ram, rom, modules everything needed for fixing with HDD repair 2.0 ENG this Maxtor hdd, I think the above has to be extracted with this software and not with pc-3000.
model 4d04h2
hda 22a
pcba 09a
unique P1a
code DAK019k0
c2
4d040h22209P1 3902B679
K,G,C,B
Poker C.3 CPU
It is detected in safe mode as: Maxtor ROMULUS F/W DAK03OKZ (should be DAK019K0?)
Also, this software gives me a message:Found:8c0 Mods
Rodrigo
PostPosted: December 17th, 2008, 13:27
Hi ! I too have a failed 40 Giga Maxtor Diamond Plus 8 (Ardent; NAR61590 K,M,C,A ; 6E040L0510605). Would the free program HDDRepair, as advertised on this thread, rewrite the firmware ? ... I can't find instructions for using the program, or downloading firmware modules (are they built-in ?) - can someone charitable help just a little ?
I read the FAQs and many threads, and I do understand people who make a living out of HD repairs cannot give out all their secrets, BUT, I can't afford professional recovery by any means either. I'm all willing to try this software, HDDrepair, on the disk (it's toast anyway).
Thank you all and n particular, Maysoft for their patience and dedication.
Czerno
PostPosted: December 17th, 2008, 17:22
And special thanks to M. Rameez...
Czerno
PostPosted: January 3rd, 2009, 19:35
http://kwar.vndv.com/workshop.html
PostPosted: January 11th, 2009, 10:52
Hi All,
I am in between very similar problem, does any body know how to use this software.
Thanks,
PostPosted: May 6th, 2009, 4:36
Hi all!
What is the function of the 'Alloc' botton of this software?
I tried to guess it, but I am not sure...
Users browsing this forum: Google [Bot] and 135 guests
