 Post subject: Fujitsu encrypted Hdd data recovery
PostPosted: May 8th, 2009, 1:18
HardDisk Status:
2.5" Fujitsu
One Primary C:
Two extended D: & E:
HardDisk drive Encrypted with Safeguard Easy
History:
Adware removal done with a freeware
Safeguard easy application popup are thrown to complete the installation or some kind
Support guys could not fix it
The primary partition removed
Rest of the partitions are seen as Unknown or raw partitions
Queries:
Which is the best and reliable Disk Imaging software that does sector by sector / byte by byte
/ raw imaging and the image can be analysed for data recovery rather than running recovery on
the affected HDD??
Which recovery software is best suited for this kind of scenario pl?
What are the suggested recovery methods for this scenario pl?
indi
 Post subject: Re: Fujitsu encrypted Hdd data recovery
PostPosted: May 8th, 2009, 12:48
Hi. bhai
Just visit this and you will understand what and how safeguard does.
http://www.clearview.co.uk/safeguard_easy.htm
DF :)
DF :)
www.datatracksystem.net
PostPosted: May 9th, 2009, 10:52
Yes and Thanks for the info.
This is the reason why I am posting in the forums is nothing but Safeguard Easy which encrypts everything on a harddisk. This disk was whole disk encrypted and the IS & IMG guys who took it for rectification ignored the fact that without taking proper procedures primary partition can not be removed. Such an illiterate stuff at IT support what to do.
Now there should be a possible way to atleast recover the primary partition so that we can use the existing key to decrypt and then get the data.
In case of any other alternative solution is greatly advisable and yes there should be some way to recover ... right !?!
Please advice me on how to recover the data from my extended partitions.
Indi
Users browsing this forum: mima85 and 54 guests
