Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: 5400.5 problem
PostPosted: May 10th, 2009, 17:10
Hi Spildit,
Thank for summarising what Doomer wrote.
Can you work with 5400.5 and apply m0 from 7200.11 for interest,
then verify which parts of SA become overwritten.
Looking forward to receiving your revised opinion.
PostPosted: May 10th, 2009, 22:09
Spildit wrote:
Also if that makes you happier, i know how to start the factory selfscan on your drive and how to rebuild the ID when the selfscan is completed ... so i can fix the drive but you will lose all of the data.
wow
that's something I don't know
of course if you are not mistaken in your knowledge
PostPosted: May 11th, 2009, 1:36
@Spildit,
You spoiling this thread. Please buddy, type somewhere else.
parts of SA, which you are guessing do not get overwritten when
applying 7200.11 m0 to 5400.5.
What is needed for part of solution (not selfscan) is command options and specification
for terminal command m0 in Level T - period.
PostPosted: May 11th, 2009, 1:38
Chapter 2 : the discovery of hot water and effects on mankind
Chapter 3 : how to teach dad how to make children...
PostPosted: May 11th, 2009, 4:37
For some who might not know you can access 5400.5 using
same terminal specs as 7200.11, (38400,N,1,8,N) ->> CTRL-Z
you can go to C Level and obtain commands listing (Q), but
this drive does not include command options (Help).
I have no doubt all will be revealed soon.
PostPosted: May 11th, 2009, 5:45
Doomer wrote:
For that you need the factory ST code.. And I don't think anyone will spoon feed you the rapidshare.com/files link you would probably spread quicker than swine flu
PostPosted: May 11th, 2009, 5:54
Just try various combinations of this command on this golden drive. Just don't change "m" command structure to recalc your SA area and don't full format it :roll:
I see your using Acelabs version of the command.. Don't know why they do it that way :idea: :?:
derp wrote:
BlackST wrote:
Different arch = different command. Careful!
Agreed, just applied 7200.11 m0 command to good working 5400.5 and
got the same result.
Different family different command - different command options, and
no help for commands. Who's got this for 5400.5 ??
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewr
ite Retries = 00C8
User Partition Format   0% complete, Zn 00, Pass 00, SoftCnt:0, SoftPBA:0, SoftE
rrCode:0, ZnReWrite:0, ZnReCertify:0, IsRd:0, HardPBA:0
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Total Grown Defects:0 XFatalBlkAddr_PBA:0
PostPosted: May 11th, 2009, 9:25
I think it wouldn't help
PostPosted: May 11th, 2009, 10:29
who knows worth a try 8)
PostPosted: May 11th, 2009, 12:03
This drive has expired golden hour, I will come back to it later.
Aside, I got coins, lots. I mean lots, can these help :wink: :lol:
PostPosted: May 11th, 2009, 12:31
Spildit wrote:
@Doomer
So i'm wrong and you are right ! Congratullations !!!
I prefer if it would be otherwise
But no magic again
PostPosted: May 11th, 2009, 13:07
Spildit wrote:
But at least i try, and i don't guive up.
That's cool. Keep trying
PostPosted: May 11th, 2009, 13:16
Don't worry I have started interesting about some brand/drives 2 years ago and now I play with them... so you can do it. Keep trying but please here , do fair, honest play (you know what I mean). Regards...
Users browsing this forum: Google [Bot] and 254 guests
