 Post subject: WD2500BEVE-00WZT0
PostPosted: May 13th, 2009, 7:30
Hi to all,
Have this disk that was clicking, afther open and see the heads at the microscope it was "dirty" with a white on the heads i clean it, but the disk start clikc again afther put the heads.
Anyone knows what is this "withe" thing that where in the heads off the client.
i Change with a new good heads and the problem is the same.
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD2500BEVE-00WZT0
PostPosted: May 13th, 2009, 8:30
Contamination inside or was the drive exposed to chemical by a chance?
PostPosted: May 13th, 2009, 8:45
"another one bites the dust."
Airborn dust particles do a LOT of damage to HDD platters.
PostPosted: May 13th, 2009, 9:03
It's not particle as there's a filter on breather hole...
PostPosted: May 13th, 2009, 10:42
no, it dont look like Particules, the heads 0 2 3 where "white" on the heads, dont know what is it !!!
ZeBong
" Россия еще раз"
PostPosted: May 13th, 2009, 10:46
Well, if there is not platter contamination, you have a BIG MEDIA DAMAGE on surfaces 0,2,3... ouch ! Check it... :(
PostPosted: May 13th, 2009, 11:31
Check color from dust filter zebong,
PostPosted: May 13th, 2009, 11:58
I look at both filters.
And it have a filter near the heads maybe the "withe" dust, that was on the heads it came from here.
The plattes look OK
ZeBong
" Россия еще раз"
Users browsing this forum: Ahmed Saeed and 78 guests
