 Post subject: Problem with my disk
PostPosted: May 13th, 2009, 3:29
I have an external USB 2.0 disk 320 gb, Western digital, NTFS file system.
The disk have many bad sectors (clusters), I want to try to repair them or mark clusters as bad.
Please, I need software to fix the disk. Tell me the programs that I have to use.
David
 Post subject: Re: Problem with my disk
PostPosted: May 13th, 2009, 4:10
hello,
if you need the disk (and not data), remove the hdd from the enclosure, and plug it in to a pc.
Get the MHDD from the files link, and run it.
Use the REMAP function.
You will have 2 options:
1. the remap will enough and the drive will be fixed, than you can reformat and use it.
2. the G list will full, (the drive will failed), or the drive will die totally
If you need the data, don't do the first case, or anything more alone, ask a pro near you!
In this case, read this:
results-the-yourself-solutions-t11912.html
Janos
PostPosted: May 13th, 2009, 9:42
Only a recert can "fix" it.
PostPosted: May 13th, 2009, 23:09
Uh... Wd selfscan... Good luck, need it!
PostPosted: May 14th, 2009, 0:14
Selfscan is a completely different thing.
PostPosted: May 14th, 2009, 0:35
there is no such thing in a program that repairs bad sectors
all these programs do is remap the drive to ignore that sector nothing more.
once the drive fills up with the g-list full of errors the drive will shut down for good.
if your information is located on the bad sector you will get errors.
and be none recoverable.
PostPosted: May 14th, 2009, 2:12
Cheaper to throw disk in trash and buy a good drive. Look into Samsung. Not worth worrying about this drive and fixing it. Trash it
Call 1-800-ROUTER-DISK-RESCUE
PostPosted: May 14th, 2009, 2:41
No. There are pros that refurbish drives professional way. I have request, for example. Such repair is at little cost, even for one piece.
PostPosted: May 14th, 2009, 5:44
Sorry, may be I do not explain very well the scenario.
I need a program to fix the disk.
I try with many programs: seatools, hddregenerator, hddscan. But i can not find a program that works with external usb drives and repair a disk.
Please help, it is my personal disk, and I want to work with it. Now when I use explore in windows, all will block, when I access to a file that is located in bad clusters.
I need the program or instead only the name of the program to use.
David
PostPosted: May 14th, 2009, 8:00
You don't find a thing that doesn't exist, AND you already have tried all the 'drive killers' around...
Users browsing this forum: Google [Bot] and 238 guests
