 Post subject: Suitable software for Disk Imaging
PostPosted: May 8th, 2009, 8:51
Can you pl suggest the best suitable and reliable software for disk imaging for the data recovery purposes?
I don't want to disturb the corrupted or damaged disk but would like to take an image - byte by byte sector by sector so that i can analyze the disk and then decide the next step.
Can you also provide me how or what software to use to recover any hard disk that is whole disk encrypted with safeguard easy?
Indi
 Post subject: Re: Suitable software for Disk Imaging
PostPosted: May 9th, 2009, 10:57
Well not to duplicate my earlier posting at
fujitsu-encrypted-hdd-data-recovery-t12181.html
The actual issue for which I had posted this query is to resolve a very particular situation I am facing now detailed at above URL.
In case any near perfect solution can be found pl mark me advised with your valuable solutions.
Tx
indi
PostPosted: May 10th, 2009, 0:49
Yes already have the image and yes all the software that was used are showing only junk. Is it recoverable or one and the same when using the recovery software on an image ?? Ofcourse its a well known fact that image is the best alternative to run or a kinda test bed, just clearing myself in case of this safeguard scenario pl. Any ideas ??
PostPosted: May 10th, 2009, 21:24
since the primary partition c:\ was deleted by he IS folks can u help me on how to recover that partition so that I can reestablish that partition and decrypt so that I can get my data back pl !?? I meant can u guide me pl !!!
PostPosted: May 10th, 2009, 21:42
You are going to need to purchase a good partition restore program. Something like Partition Doctor or another one. Do not use a free program purchase one to use you can find some good one on internet do a search and you will find one that will help you
Call 1-800-ROUTER-DISK-RESCUE
PostPosted: May 11th, 2009, 13:25
Good advice decrypt first but if you do not see partition it is not possible. First find partition then you can decrypt. Partition normally are not crypted. You can try WinHex to see the signature of your partition. This might tell you if partition is really deleted or it is still there and you are having problems seeing it. It can also show you data on your drive. Normally I use partition recovery software but never tried test disk you can give that a shot to see if it works before buying software
PostPosted: May 14th, 2009, 6:20
Safeguard and most other disk encryption software still need a standard partition table. The MBR code may be different as the start offset for the boot loader may be differnet and the encryption key may be either in the MBR or the boot sector.
If the partition is in a container file, then you would only need to pull off the container and apply the software password to access the virtual drive in the container.
https://www.mjm.co.uk/
PostPosted: May 17th, 2009, 0:19
Thanks all for your advices and there we are SCRATCHY u CATCHY my point ... This is where I need help in resolving the partition table. Unless I restore the deleted partition I can neither proceed or use any safeguard key to decrypt and then recover encrypted data. Can you help me out??
Indi
Hope is like a cloud sometimes it rains...
sometimes it passes away with a gentle smile :)
PostPosted: May 17th, 2009, 15:13
Partition doctor is a very good one to rebuild partitions with. Then you can decrypt the disk after wards. You can also check with WinHex to see the start of your partition signature. Linux Live CD also has some very good functions inside of this for your problem
PostPosted: May 17th, 2009, 23:52
I have had really good luck rebuilding partition with Partition doctor. It has saved me a lot of time using this software. You will need to rebuild the partiton before decrypting this drive. You need the partition before you can run your program. Even if you try to decrypt before rebuilding the partitons that has been deleted you will get nowhere. Get a good partition software to help you find your missing partition. Good luck on this one
Iorana Haraharaini
PostPosted: May 19th, 2009, 14:04
If the drive is encrypted with SafeGuard no "partition recovery" software will be able to find or rebuild the partition. Most of them work by finding BIOs parameter blocks and Master File Tables all of which will be encrypted. If you lost the MBR things get more complicated, Safeguard stores information on the MBR which is needed to decrypt the drive, among other things it stores a value that points to where the on the drive the security kernel is. Without the security kernel you won't be able to decrypt the drive, did you get 100% of the drive? if you didn't manage to get the sectors that contain the security kernel then you have to restore it from a .svf file (which is created from a backup of the kernel).
To do all of this you need to use a Safeguard Bootable Rescue Image for the right version of Safeguard. you can either use a floppy disk or a bootable cd.
