 Post subject: WD2000JS-00MHB0 translator failed
PostPosted: May 18th, 2009, 2:52
Hi Guys
I have WD2000JS-00MHB0 with 1 head failed, disabled through headmap and no longer clicking, check all modules and found translator mod 31 error.
The problem is, i cannot regenerate translator without all functioning heads, if i enable the previously disabled head the drive clicking continuously.
DE head map building failed after 80% with a message "Error execute=Translator regeneration error Techno CMD sending error Device Error Detected: "DM TRANSLATION OUT OF RANGE"
Any clues? the last resort is to do head exchange which i would like to avoid if i can.
Thank you.
 Post subject: Re: WD2000JS-00MHB0 translator failed
PostPosted: May 18th, 2009, 5:07
I think you can't avoid a headswap in this case.
PostPosted: May 18th, 2009, 7:08
Hi terranova,
When you disable the head, you can not copy the data with DE.
I have some cases like that and it can not copy it give error.
I Think iff the translator was ok you can not also copy the data because you have heads disable.
I know one way to do this, maybe is there any other way, to get the data from the others heads ;)
ZeBong
" Россия еще раз"
PostPosted: May 18th, 2009, 11:58
Hi Again,
Today i received a disk WD1200JS-00MHB1, that head 1 is off i disable it, and i could copy only the first sectors off head 0.
When i try to build the head map it also give me error :(
I had other case Kermit, that head 0 iss BAD the others Ok, i can build the head map Ok, but i can not copy any head in that family.
ZeBong
" Россия еще раз"
PostPosted: May 18th, 2009, 12:30
If WD marvel has damaged system head (0 or 1) you cannot copy data by health heads. If you'll disable head you get a translator problem. Switching off head is only for HDD repair/checking which of heads are corrupded. Cloning in DE by head map wont help 100%.
Let's wait genuis solution from ACE....
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: May 18th, 2009, 21:04
According to ACE i need version 4.2 for diasbling head through RAM?
PostPosted: May 18th, 2009, 21:23
Thank's creator, i did some experiment on Marvel, yes you are right, once the head is disabled, i got error when trying building headmap in DE.
Thank's Zebong
PostPosted: May 18th, 2009, 23:53
Confirmed. For this thing only I love Seagate - deactivate heads cannot be simpler...
PostPosted: May 19th, 2009, 8:55
Check PM Terranova
PostPosted: May 19th, 2009, 11:37
I also have some cases that i disable head 5 and 6, and could get ID, but could not copy any head, with head maps.
ZeBong
" Россия еще раз"
PostPosted: May 20th, 2009, 0:49
Just wondering will head exchange work on this drive (same model and headmap) or the alignment is an issue ?
PostPosted: May 20th, 2009, 6:55
I think that alignment it will be your most problem.
Unless you know the secret how to do it ;)
ZeBong
" Россия еще раз"
PostPosted: May 20th, 2009, 7:27
secret ? you only need a hammer, a black & decker and eventually a forklift... come on Zebong.... :mrgreen:
PostPosted: May 20th, 2009, 7:55
hooowwww, you know the secret :)
:mrgreen:
LOL
ZeBong
" Россия еще раз"
PostPosted: June 2nd, 2009, 2:49
Update:
Head exchange does not work with this drive, as soon as head 1 is turn off the translator failed i.e cant clone.
Is there a work around on Hawk?
Users browsing this forum: Google [Bot] and 92 guests
