 Post subject: HDT725040VLAT80
PostPosted: May 23rd, 2009, 9:15
Hi everyone
I have a problem with a Hitachi HDT725040VLAT80
This drive comes from a memup 400 GB USB external drive
The drives is not recognized by vista and is making this precise noise :
http://www.neufgiga.com/index.php?m=c9a ... a2a971add7
Can you help me to identify where the problem comes from : electronic ? mechanic ? pcb ? engine ? :|
If it's the PCB, does anyone have this model ?
Here is a picture of the drive :
Thank you :D
 Post subject: Re: HDT725040VLAT80
PostPosted: May 23rd, 2009, 9:32
99% it's the spindle stuck.
Almost certainly due to it being dropped or knocked over.
PostPosted: May 23rd, 2009, 10:08
Tks for your answer pcimage
What are my chances then ?
Is there any tuto about solving this kind of problem ?
PostPosted: May 23rd, 2009, 11:28
Seized spindle problem usually requires platters transplant to get data. Drive itself is unfixable
Success of such a procedure in majority depends of experience and skills level
I doubt it can be done successfully by somebody with 0 experience
PS: Sorry if that doesn't work for you
PPS: If you played Diablo you should understand :mrgreen:
PostPosted: May 23rd, 2009, 11:40
Chances less than zero...
PostPosted: May 23rd, 2009, 11:57
I've been able to free up spindles on the Hitachi 400s and 500s to recover data, without a platter swap. So I would give the odds as being better than 0%.
Is it possible for someone without a clean room to do it? Yes, it's POSSIBLE, but definitely NOT recommended! Platter swaps are another matter, and the odds would be 0% for that procedure.
Jono
http://www.datasaversllc.com
PostPosted: May 23rd, 2009, 13:04
Yes but we're GURUS :D
PostPosted: May 23rd, 2009, 14:34
I don't recommend without a clean room.
Because it will be contaminating the plate(s),
if now everyone that came here, thing that can open a disk without been contaminated.
i see that i will have a lot off new cases. :mrgreen:
ZeBong
" Россия еще раз"
Users browsing this forum: Google [Bot] and 267 guests
