 Post subject: Re: westerd digital burnt board
PostPosted: May 25th, 2009, 14:53
hi,
i have not written to the rom on the burnt board...
PostPosted: May 25th, 2009, 15:02
if u did not write the native ROM, then still safe. Replace the Native ROM to the Donor PCB. have fun. and if u did the wrong, the last option goes to Advanced Pro, complex case.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 25th, 2009, 15:10
well in the mean time... i did a hot swap in compass and started to do an image of the drive so far i am getting alot of orange reads.. no bad sectors.. so i will wait it out and see if i get an image....
PostPosted: May 25th, 2009, 15:46
Surley with such damage to the motor ic the board is in a short circuit condition and its not possible to write to the rom? Or maybe it is possible?
As the original poster is unable to recognise a motor ic from a rom I would swap the rom to the replacement board and keep my fingers crossed and hope I have had a lucky escape!
PostPosted: May 25th, 2009, 15:48
I give up...
In the VERY FIRST POST YOU SAID :
"i copied the rom file from the good drive and wrote it to the deffective drive. it is spinning but clicking. it is not coming to ready. any idea? i need the data on the drive."
Then later :
"hi,
i have not written to the rom on the burnt board..."
Then :
"well in the mean time... i did a hot swap in compass and started to do an image of the drive so far i am getting alot of orange reads.. no bad sectors.. so i will wait it out and see if i get an image...."
.... make up your mind ...
PostPosted: May 25th, 2009, 16:31
DR is not a damn GAME. Its Serious. Get serious n concentrate to play.
i m confused how it does go with image when its SMOOT burn.
r u making it funny?
__________
THANK YOU
SHAHI
PostPosted: May 25th, 2009, 18:26
ok i guess i confused myself and i confused u...
when i first said i copied the rom from the defective board and saved it on the good board... i thought the rom was being saved on the SA of the bad drive.it seems all i did was save it back on the same rom...
as i have now realized my silly mistake...
i can say i have done nothing to the old burnt board. what i am now trying to do is do a hot swap using data compass and then to do an image...
Users browsing this forum: Google [Bot] and 110 guests
