 Post subject: Mass Hard Drive Testing.
PostPosted: May 29th, 2009, 18:57
Hi Guys,
I have recently been refurbishing and repairing alot of iPod Drives(1.8" Hard Drives). I normally run a low level format, surface scan and the format to fat32. Can anyone suggest a better to do this.
i have been looking to buy a rack system hdd tester from YEC.
 Post subject: Re: Mass Hard Drive Testing.
PostPosted: May 30th, 2009, 1:16
Good idea and good product. There are similar products from other mfg. - their purpose is multiple test for service center and industry. Unfortunately the cost is high.
PostPosted: May 30th, 2009, 13:27
You need to add random read and write testing for the drives - it helps to check servo system
But basically you are not doing refurbishing because refurbishing recalcs adaptives, tests heads quality and remakes defect lists
PostPosted: May 30th, 2009, 14:57
Agree.
PostPosted: June 2nd, 2009, 7:48
What other mfg sell similar products? I have only found YEC that does the rack system, which i am looking for.
PostPosted: June 3rd, 2009, 7:31
In the HDD business
Refurb = Test , Erase , check mechanics of drives + SMART etc
Recert = Factory recertification AKA SelfScan or SelfTest
PostPosted: June 4th, 2009, 14:41
In the HDD business
Is it possible to recertify Toshiba iPod Drives. How can you do a self test. I have seen it done on Hitachi, WD laptop drives etc. But not on iPod Drives.
PostPosted: June 4th, 2009, 14:50
'check mechanics of drives'
Do you mean like doing a surface scan on the drive (butterfly test, random test or seek test)?
PostPosted: June 4th, 2009, 17:05
Yes. Or do SMART EXT TEST. Recert does a lot more and drive is like brand new except the working hours...
PostPosted: June 4th, 2009, 17:14
e,
Yess, I know recert is like brand new. But can it be done on Toshiba 1.8" Hard Drives (iPod Drives) Or any other 1.8" hard drives for that matter.
I believe i am correct to say it can be done on Samsung drives, but you need the burn codes, which is hard to get?
PostPosted: June 4th, 2009, 17:47
What it be OK to complete a secure erase and then a SMART EXT test on the drive. Would that check the drive completely? After I have complete those test, would the drive be 100 % tested and working (if it pass with no errors)?
PostPosted: June 5th, 2009, 0:06
The drive will not be 100% tested but if zero err reported it will be acceptable. If you have no other option...
PostPosted: June 5th, 2009, 4:10
What tests should be completed then for the drive to be 100% tested?
PostPosted: June 5th, 2009, 7:39
Selfscan.
Users browsing this forum: Google [Bot] and 136 guests
