 Post subject: Barracuda 7200.11 Busy Fix
PostPosted: June 6th, 2009, 8:01
Hello All,
Can anyone help me to fix 7200.11 busy fix and 0lba in pc3000pci.
Thank you
 Post subject: Re: Barracuda 7200.11 Busy Fix
PostPosted: June 6th, 2009, 11:21
i tied it but i cant see anything from console, there are no problems with connectivity as hyperterminal is able to read another seagate hard drive. any one please help me to fix it, pcb becomes ready in pc3000 after disconnecting spindle motor.
PostPosted: June 7th, 2009, 0:47
which are the pins to short in read channel ?
PostPosted: June 7th, 2009, 10:18
Did you read the manual that comes with it ?
PostPosted: June 7th, 2009, 11:47
In the PC3k UDMA it is very easy to fix 0 LBA problem, just by one click solution. But hard to do in the PCI version.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: June 7th, 2009, 14:46
i dont have a manual for f3 Architecture, can anyone please help me to find the read channel pins to short as it is not detecting in terminal , but pcb shows ready after detaching from spindle in pc3000pci. i tried using the manual method with hyperterminal, but i am not getting console even after connecting pcb seperated from hddcase.
PostPosted: June 8th, 2009, 8:55
If you own a legit copy of PC3000, contact them for tech support. I'm sure that they will happily talk you through the process.
Users browsing this forum: No registered users and 97 guests
