 Post subject: HD753LJ
PostPosted: June 10th, 2009, 13:41
Hi to all,
Have this disk HD753LJ, anyone knows in UDMA how can i see the terminal ?
The PC-Seagate terminal works here ?
ZeBong
" Россия еще раз"
 Post subject: Re: HD753LJ
PostPosted: June 10th, 2009, 14:22
Yes, you can use the terminal, but i have used my own, made by myself....
For the case, let me guess:
The drive can init, appears in BIOS, you can read until about 21-26G, and than starts to clicking hardly... :)
No?
Janos
PostPosted: June 10th, 2009, 14:25
Hi Janos,
Do not know yet , i am cloning other disk, them i will connect the Samsung,
The disk have been drop to the floor, i think the heads should be BAD.
ZeBong
" Россия еще раз"
PostPosted: June 10th, 2009, 14:51
I can see the terminal log :) easy.
The log is this:
++ SU
MaxPhyHead = 0006
RPM at Handoff: 0204
PwrOnPhy@USSHOS - Released on 2008/01/26 13:15 by jiwon47.ha
DRAM=32MB SoC=26A3
SHOS-(1AA08caM.a28)
L=00000000,00000000
<SpinOn_2>KeepSpinOn!
RV Circuit Enabled
Temp : 24 degC
SpinOk
mServoStatus1 00000003
UF 3 1stGrayErr
Vel Parking!
PK_3   C:     0 H:0
SK C: 99685 H:1
S_2 0000000A 0000000A 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C:  2149 H:0
SK C:100840 H:1
S_2 00000097 00000097 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C:100840 H:0
SK C: 99315 H:1
S_2 000000C9 000000C9 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 99315 H:0
SK C: 98943 H:1
S_2 00000026 00000026 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 98943 H:0
SK C: 99290 H:1
S_2 0000007D 0000007D 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 99290 H:0
SK C:100735 H:1
S_2 00000024 00000024 00000000 00000000AP:1 C:  2001 H:0Vel Parking!
PK_3   C:100735 H:0
SK C:100523 H:1
S_2 00000066 00000066 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C:100523 H:0
SK C: 97869 H:1
S_2 000000EF 000000EF 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 97869 H:0
SK C:100303 H:1
S_2 00000035 00000035 00000000 00000000AP:1 C:  1999 H:0Vel Parking!
PK_3   C:100302 H:0
SK C: 98797 H:1
S_2 000000B1 000000B1 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 98798 H:0
SK C: 99361 H:1
S_2 0000003F 0000003F 00000000 00000000AP:1 C:  2001 H:0Vel Parking!
PK_3   C: 99360 H:0
SK C: 99218 H:1
S_2 000000AB 000000AB 00000000 00000000AP:1 C:  2001 H:0Vel Parking!
PK_3   C: 99217 H:0
SK C:100757 H:1
S_2 00000033 00000033 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C:100758 H:0
SK C: 98879 H:1
S_2 00000081 00000081 00000000 00000000AP:1 C:  1999 H:0Vel Parking!
PK_3   C: 98878 H:0
SK C: 99392 H:1
S_2 000000D7 000000D7 00000000 00000000AP:1 C:  1999 H:0Vel Parking!
PK_3   C: 99392 H:0
SK C:100494 H:1
PK_3   C:100494 H:0
SK C: 98533 H:1
S_2 00000079 00000079 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 98533 H:0
SK C: 99284 H:1
S_2 000000D1 000000D1 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
PK_3   C: 99284 H:0
SK C: 98124 H:1
S_2 0000002E 0000002E 00000000 00000000AP:1 C:  2000 H:0Vel Parking!
I connect a good disk and have this:
PSL
++ SU
MaxPhyHead = 0006
RPM at Handoff: 01F2
UtSHOS - Released on 2009/01/19 13:27 by heewoo.chun
DRAM=32MB SoC=26A3
SHOS-(1AA13fyM.a38)
L=00000000,00000000
RV Circuit Enabled
Temp : 24 degC
SpinOk
SK C:115313 H:0
ServoTable Loaded
FdtTable Loaded
Hd: 0 Zn: 0 Avg.:- 131
Hd: 0 Zn: 1 Avg.: 118
PASS
| 21 | SET_MAX | 3 | 0 | 142 | B98B |
| 21 | SET_MAX | 3 | 1 | 142 | B98B |
| 21 | SET_MAX | 3 | 2 | 142 | B98B |
| 22 | SECURITY | 3 | 0 | 143 | B98B |
| 22 | SECURITY | 3 | 1 | 143 | B98B |
| 22 | SECURITY | 3 | 2 | 143 | B98B |
| 159 | DCO | 31 | 0 | 0 | B98B |
| 159 | DCO | 31 | 1 | 0 | B98B |
| 159 | DCO | 31 | 2 | 0 | B98B |
RecordValid : 00078021
No DRM
1.5G Lp00,PwrOnDn
ENG>
ZeBong
" Россия еще раз"
PostPosted: June 10th, 2009, 15:05
yep
Heads are gone.
You need to exchange MHA to do this rec.
Janos
PostPosted: June 11th, 2009, 0:32
May be limited to head 0 and 1 but yes, need to change MHA. Drive dropped?
