 Post subject: WD3200AAJS Recovery
PostPosted: June 12th, 2009, 7:15
I've a WD3200AAJS Hard Disc, which has its connectors and the electric board probably
burnt...I want to replace the electric board with WD800AAJS...
would it match? or are there other details which i should check ?
Thank You
 Post subject: Re: WD3200AAJS Recovery
PostPosted: June 12th, 2009, 7:21
What soldering equipment do you have ?
You will need more than a soldering iron.
https://www.mjm.co.uk/
PostPosted: June 12th, 2009, 8:55
Banned User
u need to flash your rom with different firmware.
banned user
PostPosted: June 13th, 2009, 3:11
can i replace ROM also ?
do you know what ROM's symbol ? is it 'U' or 'QFP' ?
Thank You
PostPosted: June 13th, 2009, 5:08
Thank You
The symbol in the PCB white print is U.
But not all pcb have external rom, some have internal in the MCU wich is U too. :)
Janos
Users browsing this forum: No registered users and 353 guests
