 Post subject: Qantum 30GB AT Fireball plus AS
PostPosted: June 20th, 2009, 2:38
hi all
i am having an issue with the above drive.
upon startup the drive will click 6 times then it will become ready.
oonce ready it will not id drive, i launch the utility and select the drive from the list and get this
Selected family................................... : AS
Selected model.................................... : Fireball Plus AS 30.0
Model by ID....................................... : <ID IS NOT READ>
CP information collection...
CP8 length information is not found!
Selected model heads count........................ : 3
CP10 length information is not found!
Zone distribution loading......................... : Error
Zone table is not loaded!
CP4 length information is not found!
Module table and module storage reboot...
Initialization error
Error sending module table reading command (Device error detected (AMN;TON;ABR;<bit5>;UNC))!
can someone please help me analyse this so that i can try and recover the data from this drive
thank you
 Post subject: Re: Qantum 30GB AT Fireball plus AS
PostPosted: June 20th, 2009, 3:00
would someone have a loader they can share fr thi drive please
thank you
PostPosted: June 20th, 2009, 4:17
CP 8 / 10 / 14 are the critical modules loaded at startup especially 10 and 14 (zone table and mod config.) . The drive is recognised as factory alias upon RDY. If you have PC3000 you have ALL the resources to kickstart the drive, then you can perform further analysis.
NOTE : if you have head problems it will be likely a terrible experience because of the adaptives, i.e. more than 30-40 head swap until you find "the right one".
NOTE #2 : you should check THOROUGHLY the read channel with DDA and the signal(s) to pinpoint exactly where is the problem.
NOTE #3 : IN ANY CASE DON'T POKE WITH THE SERVICE AREA unless you are ABSOLUTELY SURE and YOU HAVE A PROVEN BACKUP OF EVERYTHING.
And there are other non-documented ways to diagnose this drive family.
PostPosted: June 20th, 2009, 4:37
Hi blackst
thankyou for the reply and information
I have the pc3000 but don't really have any resources for quantum drives and none in the update box. I will need to chech with ace on this.
Also my manual does not have info on quantum not sure if this was removed from pc3000 udma
the only loader I have is starting the drive but showing it belonging to lct family with 400mb so mabye I inner to try and locate a correct loader to start correct testing
you mentioned some undocumented methods any chance of sharing these via pm
I wanted to work on this drive in the next day and ace support won't be around for 2 days for me due to time differences
thankyou for your help
PostPosted: June 20th, 2009, 5:12
crecomp,
Where are you based?
Janos
PostPosted: June 20th, 2009, 9:01
Australia
did you want to come here and diagnose :)
PostPosted: June 20th, 2009, 9:11
@crecomp, PM me with msn/yahoo IM contact.
PostPosted: June 20th, 2009, 9:33
crecomp wrote:
Australia
Why not? :mrgreen:
I like Australia. :)
But the drive can come to me as well, if this is more easy...
For diagnose:
The drive changes the speed when try to init and does the clicks?
Janos
PostPosted: June 20th, 2009, 10:20
N.C. wrote:
[For diagnose:
Janos
You wish it was... :mrgreen:
PostPosted: June 22nd, 2009, 8:24
[For diagnose:
Janos
hi Janos
i tested it more closely.
drive spins up and sounds normal, clicks 2 times, sounds like it is slowing down, spins up again and clicks 2 more times then stops clicking, sonds like it is spinning normally and stays spinning.
Thank you
PostPosted: June 22nd, 2009, 15:35
crecomp wrote:
[For diagnose:
Janos
hi Janos
Thank you
Than the drive can't read the servo at all.
This is head/preamp/read channel problem.
Janos
PostPosted: June 22nd, 2009, 15:50
NOTE : can be PCB too and the preamp can be OK.
NOTE #2 : forget head swap ...
PostPosted: June 22nd, 2009, 16:50
suggestion:
Try to find an identical drive, and try out the PCB on the DONOR HDA.
If the donor works with the patient's pcb, than it is head or preamp.
BlactSt have right, this drive is hard.
I can help anyway, but need to get the drive in my hands.
Janos
PostPosted: June 23rd, 2009, 0:31
i found an identical drive and swapped the patient board to the donor drive and the donor drive works perfectly.
donor board on patient drive drive does not work and clicks.
looks like it is a head issue,
i swapped heads donor to patient and patient still clicks as before, is it possibly a ismatch or an alignemt issue,
patient heads in dodnr drive dont work
donor heads back in donor work correctly so head swap technicque works well
is there anything else i should look out for ?
thank you
Users browsing this forum: Google [Bot], pepe and 286 guests
