Forum rules
 Post subject: Largest single platter hard drive with head ramp?
PostPosted: June 19th, 2009, 3:01
Anyone know the answer?
I found HDP725025GLA380 but I don't know if that's the only option.
 Post subject: Re: Largest single platter hard drive with head ramp?
PostPosted: June 19th, 2009, 12:04
There *Should* be new 320GB drives out that are single platter with ramp.
PostPosted: June 19th, 2009, 14:27
I can agree with ramp, but why do you want only 1 platter hdd?
All the Hitachi has ramp, but i have never seen any with bearing problem, except one, wich was dropped hardly...
Janos
PostPosted: June 20th, 2009, 23:54
My dead hard drive is a multi platter with non-ramp heads, and as a result, makes it harder (and probably more expensive) to work with.
If I wanted to screw around with it myself and do a platter transplant, it would take a multi platter tool, and finding a way to unload the heads off the media. Doable, but not as easy or quick.
Now if it were a single platter with head ramps, I think it'd be a lot easier to swap it out. Correct?
Just asking the thread topic question to see if a large drive matching those specs exist.
PostPosted: June 21st, 2009, 3:38
I'm still curious to know why so many people
think that platter swap is the answer to their
problems. I think they read everything on the net,
EXCEPT the WARNINGS in this forum.
PostPosted: June 21st, 2009, 4:21
Please read this:
results-the-yourself-solutions-t11912.html
Janos
PostPosted: June 21st, 2009, 12:57
andrewsfm
Hitachies are the worst drives for platter transplants
Even single platter is PITA
So far Seagates are the easiest drives for platter transplants for me
PostPosted: June 21st, 2009, 14:27
I'm afraid they don't read at all, they watch the pictures only... :mrgreen:
PostPosted: June 21st, 2009, 20:03
How are the Seagates easier to swap out than the Hitachis?
I currently have all Seagate drives after a suggestion by a DR expert a few years back, but hopefully I'll never have to worry about that with proper backups.
PostPosted: June 21st, 2009, 23:05
You'll never know until you try :)
Users browsing this forum: No registered users and 82 guests
