 Post subject: WANTED: WD3200KS-00PFB0 dcm:xxxxCAxxx >look> pics and sound
PostPosted: May 7th, 2008, 4:44
Wanted to buy:
Western Digital
WD2300KS - 00PFB0
DCM: xxxxCAxxx (mine is HSBHCAJCH)
Looking for help/advice as well. Read related posts on the forums. Please tell me if I'm missing something obvious. I was trained as an electronics tech years ago and would like to repair it myself.
Thanks for the help and interest... Colin. (cbex)
Whirrr...Click, Whirrr...Click, Whirrr...Click. Spin down.
Tested R120 and Q3 on the board. They are OK... Firmware???
Think I'll try PCB first, then replace write heads or transplant platters.
This drive was in a RAID0 array (stupid, stupid me)
There was about 1 disk failure on boot a day for three days then, BOOM:
No boot and the clicking noises started. Want to hear the noise???
Click this link to hear: http://www.atcost.org/need_hd/WD3200KS_noise.WAV
Click this for better pictures: http://www.atcost.org/need_hd
 Post subject: Re: WANTED: WD3200KS-00PFB0 dcm:xxxxCAxxx >look> pics and sound
PostPosted: June 30th, 2009, 22:30
Did you find one? I am in the same boat. My pfb burnt. If you found a lead on boards, let me know.
TIA
BOsuck
PostPosted: July 1st, 2009, 1:46
I did get a donor, and I tried the salvation-data device and I transplanted heads twice to no avail. Bye-bye data. There was more that could be done, but I gave up at that point. I still have 2 00PFB0's
1: my old drive which quit and has head or other internal problems. (13 feb 2006)
2: a donor that I bought and transplanted one set of heads from. (04 may 2006)
both have pcb's that I believe are working fine, however I did swap the firmware chips at one point and switched them back, and I also was switching boards back and forth between drives, etc. I have no reason to believe that either of the PCB's would work assuming the firmware is correct or made to be correct.
the pcb's both are the same number:
2061-701393-800 AA
let me know if you need anything, as I am done playing with this stuff.
PostPosted: July 1st, 2009, 10:21
So at this point, neither of the drives work, right?
PostPosted: July 1st, 2009, 19:24
cbex,
Im new to this, it turns out I wrote the wrong number- that was off the bar code sticker not the number stamped on the pcb
The correct number is - 2060-701393-002 Rev B
Do we got a match?
Users browsing this forum: No registered users and 85 guests
