 Post subject: Flash Memory Question
PostPosted: July 2nd, 2009, 23:20
Long story short, I confused 2 micros SD cards, and I format the wrong card, and then completely filled it with data. By the time I realized, it was obviously too late. My question, is the data that was on there completely gone and been overwritten with the new data? Any way to recover?
 Post subject: Re: Flash Memory Question
PostPosted: July 3rd, 2009, 0:09
simple theory.. overwritten data can not be recovered...
Your case maybe can be recovered but of cource con not be 100%. Depend
it is 2 GB. if after format you use already 1 GB. then your chance is just 50%. if you use it until 2 GB. then No HOPE
Спасибо
СУТИОНО / АПИНГ
PostPosted: July 3rd, 2009, 12:12
Was a 1GB Micro. I did use up the ENTIRE Capacity of the card (unfortunately). Any way to retrieve from any of the boot sectors?
PostPosted: July 3rd, 2009, 12:37
No, there is no hope.
Maybe from your hard drive, where the original data is from.....
Janos
PostPosted: July 3rd, 2009, 18:12
Absolutely no chance if you've filled it up again, 100% sure data is overwritten and gone.
PostPosted: July 4th, 2009, 1:53
Might be a selling argument for a new type of memory:
OESC Memory: On_error_stretch_capacity
Just the question, how the memory should recognise that the
user is dum ... Perhaps one should implement a part of
Windows Vista software - every time one wants to write or
erase something on it, one is asked - "dear, dum user, are
you sure about what you intend to do?"
One might store huge amounts of data on a 1GB OESC SD card....
Sorry, but such an illogical question provokes an appropriate
answer ... How should it work - fill up a bottle with water, then
empty it, fill it up again with new water - and now there should
be still the old water somewhere in the bottle ????
PostPosted: July 14th, 2009, 6:45
In this case data won't be recovered.
Good comparison with bottle, falter!
Users browsing this forum: No registered users and 147 guests
