Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Toshiba PCB Problems
PostPosted: April 10th, 2009, 3:35
having the same issue, MK6034GSX rom is embeded in mcu, removing mcu is not an issue reballing the solder it back is.
anyone has a workaround or tips ?
PostPosted: April 10th, 2009, 4:12
Er.... no. Reballing is always and always will be a PITA. But that's life. There are systems to make life easier but it is always an annoying process. Time consuming and annoying. It's the other side of technology.
PostPosted: April 10th, 2009, 4:35
pcimage wrote:
Doesn't look like a regular external ROM chip to me.
But I'm willing to be stood corrected! ;-)
You are right. There is no external ROM on this model.
PostPosted: July 5th, 2009, 20:29
I assume you have checked the fuse? F1? that is a common problem for Toshiba drives.
PostPosted: July 5th, 2009, 21:17
I faced this problem about 2 years ago. I tried a lot but
couldn't find any solution to recover the data at that time.
The main processor was burnt out(including that F1 fuse).
regards
Pninja
PostPosted: July 5th, 2009, 22:12
We've done successful Toshiba MCU replacement (with re-balling) in nearest past
That's PITA but it's doable
Users browsing this forum: Google [Bot] and 185 guests
