 Post subject: WD Heads stuck in the Ramp
PostPosted: July 10th, 2009, 14:00
Hi to all,
Need an opinion about this disk, the heads stay stuck near the RAMP.
Can anyone advise me.
Please PM me.
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD Heads stuck in the Ramp
PostPosted: July 10th, 2009, 14:58
Looks like the top head there is actually up under the ramp instead of in its normal position. Last time I had this come through I had to replace the stack.
PostPosted: July 10th, 2009, 15:25
Definitely. And check the head stack for missing heads, and locate those before you put on the new stack.
http://www.datasaversllc.com
PostPosted: July 10th, 2009, 16:15
I have only seen one of these before, was a 2500BEVS. Besides the heads being destroyed there was lots of media damage; I would make sure to look closely and see if you can find any damage. The drive I have was not recoverable.
PostPosted: July 10th, 2009, 16:24
Thanks to all,
i Could resolve the problem off the heads stuck in the ramp.
When the heads came back to the Ramp, it looks that is Ok.
I will open it again, and take some pictures, and try to see better,
but when i look , i did not see any head damage or missing.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: July 10th, 2009, 19:02
Maybe that drive got lucky then :D
PostPosted: July 10th, 2009, 23:25
zebong wrote:
Thanks to all,
ZeBong
You are Very Lucky :)
Спасибо
СУТИОНО / АПИНГ
PostPosted: July 11th, 2009, 5:07
This is the occasion to point out the design of this ramp and how incredibly this system does not fail everytime...
PostPosted: July 12th, 2009, 13:54
zebong wrote:
Thanks to all,
ZeBong
Are you sure, the top head is existing?
Did you have double checked?
Janos
PostPosted: July 12th, 2009, 17:16
will double check it tomorow.
Thanks to all.
ZeBong
" Россия еще раз"
PostPosted: July 12th, 2009, 17:28
I have seen this issue some times, but all the time the head was gone and this way can the get under the ramp....
If the head is gone, the head's soldering badly scratches up the surface....
Janos
PostPosted: July 12th, 2009, 22:49
[quote="N.C."]I have seen this issue some times, but all the time the head was gone and this way can the get under the ramp....
This has been my experience as well.
PostPosted: July 13th, 2009, 3:05
the only way is to change head.
Some case will damage the platter but if lucky enough there will not platter damage or maybe just a little scracth caused by the sticking...but still can be recovered after a Head swap...
Спасибо
СУТИОНО / АПИНГ
PostPosted: July 13th, 2009, 5:17
prodata wrote:
zebong wrote:
Thanks to all,
ZeBong
+1
HddSurgery - Professional Data Recovery Tools
PostPosted: July 13th, 2009, 5:57
looks that i have lucky in this one.
It have all the HEADS :D
ZeBong
" Россия еще раз"
PostPosted: July 13th, 2009, 20:38
I am amazed that the armature didn't have enough power to rip that head off. Can you take a picture of the other side of the head? At a minimum it had to rub against the platter and form some debris. REALLY LUCKY!
Users browsing this forum: No registered users and 96 guests
