 Post subject: Broken Maxtor ARES C64K
PostPosted: July 12th, 2009, 8:26
Hello Guys,
i have here an broken Maxtor Drive. It dosn't make sounds like a broken Device.
In the Bios it is recognizing as Maxtor ARES C64K.
Could somebody help me, i don't have a PC-3000 Device but i read that this is the only way to fix the Firmware? I still need the Data.
Greetings from Germany,
Patrick
 Post subject: Re: Broken Maxtor ARES C64K
PostPosted: July 12th, 2009, 10:39
Want to send the drive for recovery, then?
PostPosted: July 12th, 2009, 13:14
Sorry to say that you have a firmware problem, but it cannot be properly diagnosed or repaired without proper (expensive) equipment such as PC3000, Salvation or Atola.
If you're prepared to send to UK, I can almost certainly recover the data for a reasonable price. Or member "falther" is in Austria and also has the appropriate kit.
Cheers
Sean
PostPosted: July 13th, 2009, 2:30
Drives form Germany arrive here too ;-)
Sie konnen uns ruhig die festplatte zuschicken wenn Sie wollen.
Wir machen Sie ein kostenloses angebot.
Mfg,
Dobre
Murphy was an optimist
PostPosted: July 13th, 2009, 3:24
Dobre is recognised pro here on this forum, based in Belgium.
He too can resolve this problem, which unfortunately cannot be DIY'd.
