 Post subject: Seagate Barracuda 7200.10 3.AAD unlock code
PostPosted: July 16th, 2009, 20:43
Anyone know the unlock code for Seagate Barracuda 7200.10 using 3.AAD firmware? Please help, new drive is locked!
 Post subject: Re: Seagate Barracuda 7200.10 3.AAD unlock code
PostPosted: July 16th, 2009, 21:41
My old drive had froze up
S/N 6qg3ekc6
ST3400820AS
Firmware: 3.AAD
400 gig
I received a replacement from Seagate since it was under warranty although it was not exactly the same, I had taken apart the back of the drive and switched them and my old drive started up. But I couldn't get the BIOS to "see" the drive.. I assume its the firm ware that is not letting me into the drive. Can anyone help Please????/ classicrock71@gmail.com
PostPosted: July 16th, 2009, 21:42
aa9vi,
If our drive numbers match up Id be willing to help you out if you could help me????
PostPosted: July 16th, 2009, 22:07
I never set a password. The damn thing locked up on a linux install that went awry. So, is there a default password? Seagate tools say it is security locked.
BIOS sees the HD, windows sees it under Hardware, but drive doesn't show up under "my computer". I read the lock prevents it from showing up. I can't install reinstall linux either. Kinda hosed.
PostPosted: July 16th, 2009, 22:50
you need special tool to unlock it.
if it is still warranty.. simple solution is bring it back to and ask for a replace
Спасибо
СУТИОНО / АПИНГ
Users browsing this forum: elektek, Google [Bot] and 88 guests
