 Post subject: WD10EACS
PostPosted: June 23rd, 2009, 21:08
how can i check to see if the board on my drive is the correct one.
this is the case
iWD 10EACS -OOD6BO drive manufactured in september 2008(donor)
WD10EACS-OOD6B1 drive manufactured in Novemebr 2008 (patient)
the boards are different
i have 2 other drives WD10EACS-OOD6BO manufactured in October and August 2004 ad they have the same board as the drive manufactured in September 2008.
i find it strange that my patient has a different board on it,
the patient is B1 as opposed to B0 does this indicate board revision numbers ?
this drive has been to someone else before it came to me
how can i test this.
Thank you
 Post subject: Re: WD10EACS
PostPosted: June 23rd, 2009, 23:14
Have you tried manually recreating the ROM from the SA?
PostPosted: June 23rd, 2009, 23:21
hi
thank you for the reply
i installed a donr board and got the drive to go ready but will not id and so on
i was able to backup all modules form the patient drive with the donor board, and backup all rom modules.
i tried using the recreate rom from sa, pointed to module 107, it wrote all modules correctly and the drive will still not id, after the above step is carried out the drive does not become ready.
Any ideas will be greatly appreciated, do i need to use the hot swap method possiubly in this case?
thank you
PostPosted: June 24th, 2009, 4:02
What are the P/N of the PCB's?
PostPosted: June 24th, 2009, 4:10
hi
patient pcb is 2060-701590-000 rev a on the white sticker it is 2061-701590-800-02p
donor pcb is 2060-701537-004 rev a on white sticker it is 2061-701537-r00 ad
thank you
PostPosted: July 24th, 2009, 17:39
I am in need of a WD PCB like your donor
Any idea where I could get one?
PostPosted: July 24th, 2009, 18:46
You should make a new topic instead of posting an unrelated question in someone else's...
PostPosted: July 24th, 2009, 19:22
you said drive had been to someone else.
Did rom sa match with rom on pcb?
PostPosted: July 24th, 2009, 21:24
Do you want to swap the PCB first? If so, find a matched PCB said 2060-701590-000 REV A, and do the rom swap. I think you have the special equipment to re-write the Rom program.
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: July 24th, 2009, 22:07
Old thread is ooooollllllllld...
Users browsing this forum: Majestic-12 [Bot] and 256 guests
